After examining fully the used VB I bought, decided to move the rooster comb to my older VB.
Reason being, it appears that the used VB has been "messed with".
A couple of the cover plates are wrong, which prevents it from going down into 1st gear position. Also, someone ground off the "lug" on the side of the housing where the spring/ball for the ratchet are, which allows the Rooster comb to move a little to far in park, allowing the throttle valve to go out a little to far, and it can get hung up. This could cause the transmission to get "stuck" in park. Don't need that.
ALso, I tried to move the part throttle shift parts to my 68 VB but, the two rods inside have a larger diameter than on my 68. Since the rooster comb did fit fine on my 68, I moved just that and put back in my 68 with the Transgo kit installed.
Now to get the transmission back onto the engine. Its a TIGHT FIT... between my header pipes, and the transmission tunnel... Amazing anyone can get an A518 into there!!
Will let you know how she runs once its back in.
Thanks again
