Author Topic: 73 Cuda proportioning valve  (Read 2445 times)
Offline RDF
  • The pain that greets me is the stick that beats me
« on: January 31, 2017 - 10:54:19 AM »
Looking for a proportioning valve for my 73 'Cuda.  It has front disc and power rear drum brakes.  I am running all new brake lines and hoses on the car and want to replace this as well.  My issue is, every site I go to doesn't seem to have one for a 73.  I've dug around here a bit but didn't find anything, so here's my question:
Can I use either this one http://www.inlinetube.com/_p/prd14/2582470741/product/1970-72-e-body-distribution-block---bl248
or this one http://www.jegs.com/i/Wilwood/950/260-11179/10002/-1 (<-- I got the link to this from an old thread on here)
or is there another link/company that sells them?
I know the 2nd one is adjustable, which is not a necessity but for close to the same price, isn't it a better option?
Bob
1973 'Cuda
If we never drown we'll never know how well it tastes....So tell me how it tastes and I'll know just how well you drowned.
My build:
http://www.cuda-challenger.com/cc/index.php?topic=45749.0
Offline 70chall440
Re: 73 Cuda proportioning valve
« Reply #1 on: January 31, 2017 - 11:44:18 AM »
Either should work, I have a Wilwood on my Challenger bc at the time I needed one I could not find a new one. If you are running a stock setup, just use the inline one and forget about it. If you want to adjust it, then the Wilwood will serve the purpose but you probably do not need that feature and it is one more thing to mess with.
Current Mopar
Past Mopars
« Reply #2 on: January 31, 2017 - 12:19:47 PM »
Soak your valve in EvapoRust and disassemble it.  If it's been sitting "dry" for a long time, you might have problems getting out the large valve on the right side of the picture.  If the inside is still wet with brake fluid, it will come apart much easier.
On my original valve, I broke the piece on the right because it was rusted in place.  I had to find a replacement from another valve.  After that broke, I didn't try removing the other brass pieces.  I just cleaned everything out really good after an EvapoRust soak.  It still works fine.
« Last Edit: January 31, 2017 - 12:23:18 PM by burdar »
Offline Cudakiller70
« Reply #3 on: January 31, 2017 - 01:13:42 PM »
I rebuilt mine also
This site has parts and info on how to rebuild
https://www.musclecarresearch.com/1970-76-mopar-combo-valve-autopsy
Also if not stock summit does have a nice one from wildwood I think
« Last Edit: January 31, 2017 - 01:15:47 PM by Cudakiller70 »
The above is just my opinion
John Adams
Offline RDF
« Reply #4 on: February 01, 2017 - 11:33:37 AM »
Thanks for the responses!  :cheers:
I'm not considering rebuilding mine at the moment.  It's been sitting off the car for 5+ years and really isn't in the best shape either.
The price difference between the stock and adjustable one is only a dollar more for the adjustable style (that's including shipping).  Do you guys think it's worth it to get the adjustable one for basically the same price as a stock one?
Bob
1973 'Cuda
My build:
John Adams
Offline 70chall440
« Reply #6 on: February 01, 2017 - 03:45:10 PM »
if you are running a stock brake setup, run a stock P valve, one less thing to mess with. If you are planning to go to rear disc or something, then the adjustable might be warranted.
Current Mopar
Past Mopars
Offline bandt
« Reply #7 on: February 01, 2017 - 07:38:54 PM »
Dr.Diff sells a 1 piece proportioning valve. I put one in my Challenger last year. I went from front drums to discs. If you are interested I have a new one.
 http://www.doctordiff.com/1-piece-proportioning-valve.html
Better
« Last Edit: February 02, 2017 - 10:01:57 PM by bandt »
