Author Topic: Correct color for Intake, Water Pump Housing, Valve covers, etc on 440-6?  (Read 1709 times)
Offline SwissCuda
Correct color for intake,  water pump housing, valve covers, water neck, etc on 440-6?
What color should this parts be painted? Orange or Gray?
Any reference pictures? A part from factory colors do you have any preferences? what looks cool and what looks factory style?
Offline 72ls5fla
Re: Correct color for Intake, Water Pump Housing, Valve covers, etc on 440-6?
« Reply #1 on: February 01, 2017 - 06:59:47 AM »
99.9% sure all the items listed were painted on the engine as an assembly.
I used the paint from Rodger Gibson - dead on correct.  needs to be sprayed with a paint gun.
Its an enamel w/o hardener.
paint on my engine is nearly 3-4 years old and never cracked or pealed.
Be vey sure the engine is wiped down and all grease is gone.
The enamel also is supposed to be painted over a bare metal block.
Bill
Offline 73440
« Reply #2 on: February 01, 2017 - 07:06:02 AM »
http://www.mymopar.com/index.php?pid=76
Some paint codes and color info
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
« Reply #3 on: February 01, 2017 - 08:59:11 AM »
The engines were pretty complete when they were painted.  A lot of accessories were already installed as well.  Water pump and housing, exhaust manifolds, torque convertor(if automatic), flywheel/clutch/bell housing(if manual), fuel pumps, spark plug wire looms.
« Reply #4 on: February 01, 2017 - 09:07:34 AM »
Motor mounts were NOT installed prior to paint.  The block drain plugs were also NOT installed before paint.  Found these two pics online for you...
Offline SwissCuda
« Reply #5 on: February 01, 2017 - 09:25:55 AM »
What is your personal preference?
I think that engine with gray exhaust manifolds and gray intake looks pretty cool...
R.
Offline 73440
« Reply #6 on: February 01, 2017 - 09:30:02 AM »
 That would make a good contrast color combo
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
« Reply #7 on: February 01, 2017 - 09:32:17 AM »
It all depends on what look your after.  If you want the factory correct look, then you need to paint the engine as a complete assembly.  If you aren't concerned about looking factory, then you can do what ever you think looks good.  I personally like the factory look but it's up to you.
Offline Tmb84
« Reply #8 on: February 02, 2017 - 10:39:04 AM »
Orange exhaust manifolds??
71 Barracuda Hemi -Sox&Martin
70 Charger 383 -Top banana
Offline tman
« Reply #9 on: February 02, 2017 - 11:12:58 AM »
Paint on the exh manifolds will burn off.  It will not be orange for long.
« Reply #10 on: February 02, 2017 - 12:15:40 PM »
Yes, the exhaust manifolds were installed on the engine before it was painted.  Most of the paint will burn off but some color will stay on the mounting flanges and fasteners.  Small blocks were the same way.  They even had the bypass hose installed before paint. No one could verify if small blocks in 73 had the fuel pump painted or not.  I chose to paint it.
« Last Edit: February 02, 2017 - 12:17:45 PM by burdar »
