The upper hinge brackets that would need adjustment to raise a sagging door are a real PAIN to get to, especially on driver's side! You almost have to remove dash to be able to get to the bolts holding the upper hinge to A pillar area. It's a two person job - or padded floor jack while you go in from passenger side to loosen and tighten adjusting bolts with door slightly open to have something to lift it.
