Author Topic: What Radiator for a Gen III in E-body Cuda?  (Read 10217 times)
Offline kjwalters
« on: February 01, 2017 - 05:28:33 PM »
Title says it all guys. What radiator are you guys running in your E-body Gen III cars?
What side do the in/out lets have to be on, and how big are they?
Thanks for the help in advance.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: What Radiator for a Gen III in E-body Cuda?
« Reply #1 on: February 01, 2017 - 06:11:06 PM »
I bought the Bouchilon custom radiator by Griffin with the inlet and outlet on the passenger side just as the engine is set up. It's not cheap but nothing on this swap is.
http://bouchillonperformance.com/products-radiators-gen3
Buy their upper rad hose but the bottom doesn't fit, so I just bought a '70 cuda hose and trimmed it a little and it fit perfect.
Another option is the Radiator House Icebox rad. It's about the same price as Bouchilon but is darker and looks more stock. This is the radiator Graveyard Carz put in their '71 Cuda.
http://radiatorsupplyhouse.com/products/icebox-performance/
One thing to note, if your hook up the fans to the mopar wire harness they will not turn on until 228ish and off at 215ish. This pretty much pegs my temp gauge. I talked with the mopar engineer that designed this harness and he said that's the normal op temp of this engine. It's too hot for me, so I'm taking my Cuda in to a local tune shop to adjust that setting via a HP Tuners software update that is now available for this PCM.
Offline GoodysGotaCuda
« Reply #2 on: February 01, 2017 - 07:21:04 PM »
What size is the upper fitting on your radiator?
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline kjwalters
« Reply #3 on: February 01, 2017 - 10:22:40 PM »
That's awesome thanks for the help.
Offline dfrazz
« Reply #4 on: February 01, 2017 - 10:28:30 PM »
Not sure but this is the hose.
http://bouchillonperformance.com/inc/sdetail/10324/7624
You also need an overflow tank.
Offline 70chall440
« Reply #5 on: February 01, 2017 - 11:02:36 PM »
I met the guys from Icebox at SEMA, really a family owner and operated business that cares about what they do.
Current Mopar
Past Mopars
Offline diyhemi.com
  • Formerly Yellowfin
    • DIYHEMI.COM
« Reply #6 on: February 02, 2017 - 10:22:02 AM »
Champion Hemi swap radiator with both inlet/outlet on passenger side. 3 row aluminum for $230 shipped to my door
1970 Barracuda Gran Coupe, gen III project (Cone Killing Cuda)
Offline kjwalters
« Reply #7 on: February 02, 2017 - 05:26:50 PM »
WOW, that's an awesome price. Are you happy with it? Do you just call champion radiators or do they have a web page?
Thanks again.
« Reply #8 on: February 02, 2017 - 07:54:41 PM »
Thanks again.
Go through eBay. They all come polished aluminum, but I painted mine.
1976 Dodge Warlock
Offline kjwalters
« Reply #9 on: February 02, 2017 - 09:12:02 PM »
Thanks, Your engine compartment looks great by the way.
Offline djw383
« Reply #10 on: February 02, 2017 - 10:24:07 PM »
Painted, looks awesome!!
Sent from my HTC6525LVW using Tapatalk
Offline ShelbyDogg
« Reply #11 on: February 11, 2017 - 01:23:16 PM »
I used a standard 26" big block radiator that I had in my garage. Bought a flexible top hose from Oreillys and used the stock bottom hose from a Chrysler 300 that was still attached to the 5.7 when I bought the engine.
Offline dfrazz
« Reply #12 on: February 12, 2017 - 11:44:58 AM »
That looks 26", right?  Mine was 22" and I could not find one that fit without modifying the rad support.  Also, the last thing I wanted was any kind of heat issues with this engine.
Offline ShelbyDogg
« Reply #13 on: February 12, 2017 - 12:30:21 PM »
You should have just put in the 26" radiator conversion piece if you don't want cooling problems. Everyone uses A/C now and the piece is only $99. Then you could buy the 26" big one.
Offline daryld
« Reply #14 on: June 12, 2017 - 10:59:33 PM »
Looks good. Did you have to modify your firewall for the Gen 3 install?
Thx
Daryl
Daryl
