Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
71 340 4 barrel 727 trans kick down spring
« previous
next »
Print
Pages: [
1
Author
Topic: 71 340 4 barrel 727 trans kick down spring (Read 1080 times)
culp71
Full Member
on:
February 02, 2017 - 10:52:34 AM »
what, if any, is the correct for a 1971 340 (4 barrel shaker) 'cuda transmission kick down spring setup needed?
Last Edit: February 02, 2017 - 10:55:46 AM by culp71
Logged
mopar jack
Full Member
Re: 71 340 4 barrel 727 trans kick down spring
Reply #1 on:
February 02, 2017 - 11:24:29 AM »
If you mean kick down linkage try this video.
https://www.youtube.com/watch?v=FY9WTWayCC8#
Logged
culp71
Full Member
Reply #2 on:
February 02, 2017 - 01:00:42 PM »
helpful over all but where does one find the correct spring for the kickdown linkage?
Logged
mopar jack
Full Member
Reply #3 on:
February 02, 2017 - 01:30:44 PM »
The spring in the video just holds the linkage to the rear. You can have someone step on the throttle and hold it to the floor making sure that the carb is in the full open position then push the kick down rod towards the fire wall until it stops and adjust the link.
Logged
culp71
Full Member
Reply #4 on:
February 02, 2017 - 03:28:33 PM »
so no spring is needed for it?
Logged
YO7_A66
Jr. Member
Reply #5 on:
February 02, 2017 - 04:29:42 PM »
You need the spring installed to keep the linkage snug against the carb pin.
You can get the spring from the restoration parts houses or you can get a universal spring kit from your local parts house and cut/bend to suit. This is a universal spring kit that I found on Autozones websight for reference. There are other kits too.
Last Edit: February 02, 2017 - 04:33:54 PM by YO7_A66
Logged
culp71
Full Member
Reply #6 on:
February 06, 2017 - 03:12:32 PM »
found it, year one part # BF341
looks to be correct.
Last Edit: February 07, 2017 - 10:43:46 AM by culp71
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
