Author Topic: Stock Electronic Distributor Wiring Question  (Read 702 times)
Offline daveh
« on: February 04, 2017 - 01:07:56 AM »
Hey guys,
I need to splice in my old stock electronic distributor to my new distributor and the wire colors on each are different.
The one on the old distributor are yellow and black and the ones on the new one are red and black.
1. On the old distributor what are the white and black wires for?
2. Can I splice the black to black and white to red?
https://p32-mailws.icloud.com/wm/messagepart/IMG_1202.JPG?guid=messagepart%3AINBOX%2F4068-4&type=image%2Fjpeg&uniq=hoodsfive&name=IMG_1202.JPG&size=160040&dsid=8171652265&clientId=6F8FEF8A-D27F-4CD4-81BC-6B75EECFED38
https://p32-mailws.icloud.com/wm/messagepart/IMG_1201.JPG?guid=messagepart%3AINBOX%2F4068-2&type=image%2Fjpeg&uniq=hoodsfive&name=IMG_1201.JPG&size=180098&dsid=8171652265&clientId=6F8FEF8A-D27F-4CD4-81BC-6B75EECFED38
Thanks
Re: Stock Electronic Distributor Wiring Question
« Reply #1 on: February 04, 2017 - 09:23:14 PM »
Well I cannot see any pix but it is a simple in & out circuit  but it needs to be wired correctly  if you hook it up one way & it runs badly swap the wires
Offline daveh
« Reply #2 on: February 06, 2017 - 03:08:21 PM »
I called Pertronix and here is what I found out about the wiring .  The stock Mopar connector isn't used any longer
Here is where the Pertronix wires coming from the new distributor go:
Red wire - Goes to a hot ignition source
Black wire - Goes to the coil negative.
Sound about right?
Thanks
Offline daveh
« Reply #3 on: February 06, 2017 - 03:11:34 PM »
Is one of the yellow or black the hot for the ignition?
