Author Topic: Remote Driver Mirror Routing - Pictures??  (Read 2147 times)
Offline chaps70rt
  • 70 Challenger R/T Hardtop in Progress (Canada)
« on: February 11, 2017 - 06:42:20 PM »
I have been searching the site for some information on the routing for the remote mirror cables on the driver door.   I have tried numerous routes and the glass keeps hitting the cables.    If someone has pics of the connections points along the route, I am sure others would also benefit.   My car was partly disassembled when I purchased it including the mirror cables left inside the door.   The replacement cable is an aftermarket, so perhaps the cables are too short .... I hope not!   :swear:
A picture is worth a thousand words, but if it can be explained I will take whatever help I can get.
Thanks  ..... Chaps!!
 :canada:
White 1970 Challenger R/T
440 - 4BBL - Shaker
Daily Driver - 2014 Dodge RAM 1500
Stouffville, Ontario Canada
Offline chadb
Re: Remote Driver Mirror Routing - Pictures??
« Reply #1 on: February 11, 2017 - 10:16:30 PM »
I need this info also, installing my mirrors today, running into the same issues
Offline cudamadd
    • cudamad157071@gmail.com
« Reply #2 on: February 11, 2017 - 10:40:10 PM »
There is a thin bracket about 6 to 8 long with a factory drilled hole which you bolt 2  the inside of your door it only has one short bolt and the mirror cables pass throw this hole and r keaped away from your glass . The bracked has a round edge at the top and then go changes shape at the bottom .Ifi find a picture or reference number i will post it  :aussie:
Go 4 a spin Ya Why Not.
Offline cudamadd
« Reply #3 on: February 11, 2017 - 10:53:30 PM »
Sorry i have trouble with pictures .Buy if you want to see the bracket you need eBay # 262735749251 . The want way 2 much .So you will find one at junk yard or swap meet
Offline blown motor
« Reply #4 on: February 12, 2017 - 09:45:20 AM »
On my 74 there is a plastic loop that is attached to a part of the framework near the forward end of the door. The cable goes from the mirror, through that loop and back to the remote handle. This holds the cable forward of the window. Perhaps you are missing that plastic loop. I think you could duplicate it with a zip tie.
« Last Edit: February 12, 2017 - 12:18:59 PM by blown motor »
Offline chaps70rt
« Reply #5 on: February 12, 2017 - 11:41:23 AM »
Thank you both for your feedback.    I am pretty sure that I have the metal plate with the large hole still on the door.    The plastic piece??   I will need to check for, but the zip tie plus the type that have the screw holder incorporated would be a good alternative if missing to attach it near the front.
Hopefully this resolves the mystery and I can get me door panel on for good and functional!!
Cheers!! :cheers:
440 - 4BBL - Shaker
