Author Topic: Brakes  (Read 753 times)
Offline ragtopman
Brakes
« on: February 12, 2017 - 02:05:16 PM »
I had to install a new master cylinder on my car, but when I went to bleed the system I got fluid out of the right side wheel cylinders only. Nothing from the left side. I think its the distribution block, any body else have this problem?
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: Brakes
« Reply #1 on: February 12, 2017 - 03:08:28 PM »
Did you bench bleed the MC?
Offline ragtopman
Re: Brakes
« Reply #2 on: February 13, 2017 - 12:08:33 AM »
yup, that is how I know fluid comes out the one side only cause I have one of those Motiv power bleeders(excellent tool also). Your from Colo.(I'm in the Springs).
Re: Brakes
« Reply #3 on: February 13, 2017 - 08:35:45 AM »
The way this reads is your getting fluid out of both right side cylinders(plural).. The distribution block might make sense for the front but not the rear, a single line goes to the rear axle where it T's to the L/R brakes.
When rebuilding my brakes one of the bleeder's was clogged which took some effort to clear out.. On the front I doubt the block is the problem, by the time the fluid gets to it's T it is already past the working parts although it is possible it could be clogged there.
Offline 69bcuda
Re: Brakes
« Reply #4 on: February 13, 2017 - 11:22:36 AM »
You could try cracking the line going in to the wheel cylinder while applying pedal pressure to verify whether you're getting pressure or not to the cylinder.
