Author Topic: Rear end rebuild  (Read 3427 times)
Re: Rear end rebuild
« Reply #15 on: February 25, 2017 - 08:44:49 AM »
So which one did you end up going with? And did you just buy a separate pinion nut?
I went with the Richmond kit that claims to be for a 10 spline pinion but it actually comes with a nut for a 29 spline pinion.  :screwy:
Also found out the Motive Gear bought Richmond. Just a little trivia.
Offline GoodysGotaCuda
« Reply #16 on: February 25, 2017 - 09:22:08 AM »
Be sure you have a small beam torque wrench for checking turning torque. A clicker-type will not work.
[look for a 1/4" drive bicycle one to get low enough]
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline Rdchallenger12
« Reply #17 on: February 25, 2017 - 09:36:50 AM »
Hahahaha good info! Thank You
« Reply #18 on: February 25, 2017 - 10:41:28 AM »
Thanks for info Goody.
Recently a friend introduced me to a friend of his that does rear ends for a living. He said after I get all the parts, to come over to his place and we can build it up together.  :smokin:
« Reply #19 on: February 25, 2017 - 12:26:06 PM »
Good deal, that's how I learned as well. I've done dozens of setups since then.
1976 Dodge Warlock
« Reply #20 on: February 27, 2017 - 08:04:02 PM »
And I can guarantee you that the kit comes with a nut for a 29 spline pinion. Just picked up the pkg today and checked. Fits the new Yukon 29 spline pinion.
