Author Topic: 74 Cuda Restomod  (Read 6988 times)
Offline RCCDrew
Re: 74 Cuda Restomod
« Reply #15 on: March 11, 2017 - 04:47:20 PM »
Very cool. I saw that hemicuda in Baytown several years ago before it was sold. I was a show judge at the lone star shootout. Nice car.
Offline Cuda70-74
« Reply #16 on: March 12, 2017 - 05:45:56 PM »
Yes it is a nice car from pictures.
Offline Cuda70-74
« Reply #17 on: March 12, 2017 - 05:47:00 PM »
Quick question I was wondering if you can replace the trunk floor pan without removing the rear taillight panel?
Offline usraptr
« Reply #18 on: March 12, 2017 - 07:32:59 PM »
Depends on whether you buy a one piece trunk pan or two piece.  With a one piece pan you pretty much have to remove the tail panel.  I used a two piece for mine, but removed the tail panel anyway since we ended up replacing the quarters after-all.  Good luck with your build.  :2thumbs:
(Edited 8-1-17)
Offline redo1973
« Reply #19 on: March 12, 2017 - 09:12:02 PM »
I thought that I've seen a full trunk floor inserted through the tail panel when you remove that 4 inch angled piece connecting the floor to the tail panel.
Offline Cuda70-74
« Reply #20 on: March 12, 2017 - 09:22:55 PM »
I will be getting the whole trunk floor pan. I think I might have found a way to do it without taking out the tail light panel
« Last Edit: March 12, 2017 - 11:02:35 PM by Cuda70-74 »
Offline Cuda70-74
« Reply #21 on: March 17, 2017 - 12:27:00 AM »
I thought some of my sheet metal would be here today but no hopefully this weekend. I did get my qa1 front k-member  tho
Offline Cuda70-74
« Reply #22 on: March 17, 2017 - 07:59:40 PM »
Tear down the front end of the cuda today. It's a pretty solid car up front. I do need to get a new front core support tho.
Offline Cuda70-74
« Reply #23 on: March 17, 2017 - 08:11:03 PM »
Dam the cuda doors are heavy. I got a few questions. I see some guys are welding in fender brace I was just wondering are the stock ones bad. Also does anybody know what year  these bumper brackets go for and fender support??
Offline Cuda70-74
« Reply #24 on: March 26, 2017 - 12:22:10 PM »
I got my sheet metal in that I order. Now time for the fun part cleaning up 40 years plus of road grime and rusty :cooldancing: . I also took out the rest of the trunk pan I'm still debating if I should replace the tail light panel.
Offline usraptr
« Reply #25 on: March 26, 2017 - 07:45:56 PM »
Looks good!  :2thumbs: Been there done that!   :bananasmi
(Edited 8-1-17)
Offline Cuda70-74
« Reply #26 on: March 26, 2017 - 09:24:19 PM »
Thanks. I'm going to use ur build as blueprint for my build
Offline Cuda70-74
« Reply #27 on: June 28, 2017 - 08:45:47 PM »
It's been a while since I did a update on my project. I was working on my garage and getting some air tools. Now I'm back on the cuda. I finish removing the passenger side outer well wheel which was a pain.
Offline Cuda70-74
« Reply #28 on: June 28, 2017 - 08:53:59 PM »
I also been working on my trunk floor and drop off pans. I also have a question how did u take off that piece of trim on the tail light panel that i have circled in red. I also have my 74 cuda grill for sale in going with a 71 cuda front end.
Offline larry4406
« Reply #29 on: June 29, 2017 - 06:00:31 AM »
That trim piece has bolts with special clip/heads that engage the u-shaped part of the trim.  The studs with nuts are accessible from inside the trunk.
