Author Topic: reverse brake light wiring, 71 E Body  (Read 927 times)
Offline DocMel
« on: February 19, 2017 - 04:16:35 PM »
I did have a 727 tranny.  The reverse light hook up to the 727 tranny is a 3 prong (female) .
I'm now running a Tremec 5 speed manual, which has a two prong hook up (male).
Could anyone give me a hint at which wires go where on the two prong on the Kiesler?
To make this situation a little more difficult, on the three wire prong, I cant really tell what color the wires are.  They are in- line, and each wire has its on prong (female) is about all I can tell.  The reverse lights did work before the switch to the manual tranny
Offline shawge
  • Zoiks!!
Re: reverse brake light wiring, 71 E Body
« Reply #1 on: February 19, 2017 - 05:35:00 PM »
Order does not matter.  Just connect them up.  Works great on my TKO.  :cheers:
- Jerry
Offline lulurocks
« Reply #2 on: February 20, 2017 - 05:17:36 PM »
The two outer wires on the old nss are you reverse light circuit .    Center goes to the ground  when the old tranny was in park or neutral grounding the starter relay .
