Author Topic: Installing a Victor 383 - Q about bolts for cylinders 3 and 6  (Read 717 times)
Offline shawge
  • Zoiks!!
« on: February 25, 2017 - 01:36:44 AM »
Installing a Victor 383 - all of the intake bolts go in just fine except 2 due to the bolt hitting the runner during install.
This is the bolt for cylinder 6 and cylinder 3 is the same. Bolt is an ARP 3/8" diam  1-11/16" length
Not sure how to move forward here.  :clueless:
Do I use a grinder or rat tail file to enlarge the hole for the bolt?
Or do I use a shorter bolt?  A 1-1/4 bolt goes right in but the thread engagement is IMO marginal so something 1-3/16 to 1-1/2 range.
Or something else?
Thanks.
- Jerry
Offline larry4406
Re: Installing a Victor 383 - Q about bolts for cylinders 3 and 6
« Reply #1 on: February 25, 2017 - 06:13:14 AM »
Install those bolts hand tight first while holding the intake up and away from the head to eliminate the crash followed by the others?
« Reply #2 on: February 25, 2017 - 09:03:37 AM »
typical , I would use a shorter bolt if possible or grind a small relief into the wall of the runner
Offline shawge
  • Zoiks!!
« Reply #3 on: February 25, 2017 - 09:58:50 PM »
Thanks guys, after grinding a slight relief the bolt goes right in.  Now to finish the install  :biggrin:
- Jerry
« Reply #4 on: February 26, 2017 - 11:00:57 PM »
 :2thumbs:
