Author Topic: Ignition switch problems, help!  (Read 1236 times)
Offline cuda2420
« on: February 27, 2017 - 02:14:23 PM »
I have a broken ignition switch in my 1970 Cuda and when tried to change it I found out out that the previous owner had welded the the steering wheel adapter to the shaft so I can no longer get into the steering column to access the ignition switch.
My question is witch wires do I connect to make a set up where I use a flick switch for RUN position and then a push button for the START position?
Any Ideas on how to wire this is much appreciated.
Re: Ignition switch problems, help!
« Reply #1 on: February 27, 2017 - 08:16:01 PM »
Haven't messed with the ignition wiring in a while. I think the brown is start, blue run. So flick the blue and push the brown.
« Reply #2 on: February 27, 2017 - 08:29:46 PM »
You forgot the Yellow that trips the start relay
« Reply #3 on: February 27, 2017 - 08:43:07 PM »
Yup. No foolin the bullitt. Yellow will have to be pushed too.
Offline cuda2420
« Reply #4 on: February 28, 2017 - 05:50:01 AM »
So if I understand this right I need to get constant 12V on the blue wire to turn the ignition on (first step) where would you guys take 12volt from? witch wire should I connect with the blue wire via the new flick switch?
« Reply #5 on: February 28, 2017 - 06:42:38 AM »
All power comes in on the big red wire to the column
Offline EbodyMod
  • Will it ever be finished????
« Reply #6 on: February 28, 2017 - 08:24:37 AM »
I have an extra 1971 auto p/s column, the knuckle end of the shaft has been cut off. but if you want to pay for the shipping it is yours. it worked but I wanted to get rid of the column shift. the shaft was cut trying to install unisteer POS.  (ripped it out and put in Firm Feel)
:wavingflag:  Quit being offended by everything, I am sure you are doing something that upsets me, but I am not complaining about you!!! It is a free county get over yourself!
Offline cuda2420
« Reply #7 on: February 28, 2017 - 02:25:38 PM »
Should I run the flick switch between the big red (battery 1) and the brown wire (ignition 1)? and what should I do with the blue wire with white tracer (ignition 2)?
« Reply #8 on: February 28, 2017 - 04:00:02 PM »
Blue is the Run power that goes through the Ballast Resistor so you will need power there full time.
Yellow wire goes to the start relay & Brown wire directly to the ignition during startup.
All power would come from the Big Red Wire.
Offline cuda2420
« Reply #9 on: February 28, 2017 - 04:11:59 PM »
I no longer use he ballast reesistor with the MSD 6AL ignition box that I run, If I understand this right I could have blue and brown on one side of the flick switch and the big red (battery) on the other?
« Reply #10 on: February 28, 2017 - 06:17:39 PM »
Yup.
And the yellow starter wire on the push. Again, using the red for power source.
