OK 8 PACK,
That sounds good, but there is a rubber gasket keeping the sending unit isolated from ground. The tank may be grounded, but not the sending unit. The pick-up tube that the rubber hose connects to, should be grounded also. There is a metal strap that clamps onto the pick-up tube and clamps onto the solid fuel line too, thus connecting the sending unit to ground. Is that metal strap there? I can send you a picture if you need to know what I'm talking about.
