Charger Shifter Question
Author Topic: Charger Shifter Question  (Read 1018 times)
Offline Carlwalski
« on: June 29, 2005 - 12:45:18 PM »
Do Dodge Chargers TorqueFlite console shifted cars have the same style of shifting pattern as the Slap-stik??  :???:
Do they detent or can you shift from 1st - Drive because it's just a normal style?  :dontknow:
Are all years the same? This is for a 1968 Charger.
Thanks.  :thumbs:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Re: Charger Shifter Question
« Reply #1 on: June 29, 2005 - 03:07:55 PM »
This is NOT a Charger website!!!    :stomp: :stomp: :stomp:
 I'm giving you crap NZ.  :grinyes:
I'm not sure I understand the question. Are you asking if you can drive an automatic like a manual shift? Yes, if that's the case.
Offline Carlwalski
« Reply #2 on: June 29, 2005 - 04:13:32 PM »
Hey Mike,
Sorry....ummmmmm, can you shift it hard by slapping shiftying it and it will only go one gear at a time, realease or pop back by itself the shift again. Like the slap-stik mechanism??  :D When I went for a drive in the 69 up north the guy looked like he was shifting up a few times but went a little to far and had to ease it back into the previous gear, aka NO detent.  :-\ I need detent.  :grinyes:
« Reply #3 on: June 29, 2005 - 09:30:13 PM »
the Slap Stick can be used in a Charger but the shifter is mounted further forward & the slapstick uses a much shorter handle
 the factory Charegr shifter is not like th eslap stick with a rachet function
 BTW this is not a Charger site  ;D
Offline Carlwalski
« Reply #4 on: June 29, 2005 - 09:44:12 PM »
LOL  ;D Cheers  :thumbs:
