Author Topic: 727 replacement?  (Read 1169 times)
Offline TreeFrog
    • TreeFrog
727 replacement?
« on: June 29, 2005 - 01:41:03 PM »
if i wanted to replace my 727 with a newer better trani what would I use?
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Offline 1973challenger360
Re: 727 replacement?
« Reply #1 on: June 29, 2005 - 02:03:04 PM »
 :laughup: :laughup: :laughup: :laughup: :laughup:
A newer better Tranny   you cant replace the best with another tranny,  if you want an overdrive  put on a gear venders.
If you want a manual an 833 or for an od try a 5 or 6speed.
The 727 is the best transmission ever made for a passanger car application.
« Reply #2 on: June 29, 2005 - 09:25:27 PM »
you can use the A518 4 spd based on the older 727 design But you need to modify the trans Xmember attached to the floor pan  & rear mount to make it fit
Offline TreeFrog
    • TreeFrog
« Reply #3 on: June 30, 2005 - 08:29:16 AM »
I recal there beeing a guy/company that makes a new trani designed to bolt-up in place of a 727.  light weight but still top notch...can not remember the name...probablt top dollar at that but was just curious
