Cam Bolt Question With Pics
Author Topic: Cam Bolt Question With Pics  (Read 1539 times)
Offline daveh
« on: March 06, 2017 - 08:53:02 AM »
Hey guys,
As some of you know I installed the engine and trans yesterday which went great.  My question is concerning the UCA Cam bolts.  Do they look like they are installed correctly or should I move them slightly so the pressed on washer if on the other side?  Not coming through the engine bay side just rotated to the other side of the housing.
Does that sound clear?  What I’m saying is do I push the bolt out slightly and rotate the washer to the other side?
BTW – I’ve installed the Moog offset bushings if that matters.  Thanks
Re: Cam Bolt Question With Pics
« Reply #1 on: March 06, 2017 - 09:47:49 AM »
 :dunno: :clueless:  The cam bolts will be turned to where they need to be during the alignment.  It doesn't matter where they are right now.
Offline daveh
« Reply #2 on: March 06, 2017 - 11:01:46 AM »
Ok thanks I appreciate it.
Offline 1 Wild R/T
« Reply #3 on: March 06, 2017 - 11:51:33 AM »
But I prefer to set them for maximum caster before the alignment so the alignment tech gets one extra reminder to dial in as much caster as he can.....
Offline 73_Cuda_4_Me
« Reply #4 on: March 06, 2017 - 12:52:31 PM »
You DO have the offset washers that go on the 'nut' end of the adjusting bolts, correct? You will need them for alignment!
They have flats on the I.D. that correspond to the flats in the bolt's threaded end...
Both ends of each of the adjustment bolts move the UCA IN or OUT as a pair...
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
Offline daveh
« Reply #5 on: March 06, 2017 - 12:56:24 PM »
How do I set them for max caster.  Remember I did install the Moog offset bushings.  Thanks for your help.
Offline jhaag
« Reply #6 on: March 06, 2017 - 01:03:06 PM »
Looks like front is correct and back are opposite of what you want. The front bolts should force the a frame out, the rears should be all the way in. You want the top ball joint as far rearward (toward firewall) as you can get it. Therefor looking at the car from the side, a line drawn through the top and bottom joint would have the top leaning rearward. Hope that makes sense!
love 70 Challengers
« Reply #7 on: March 06, 2017 - 08:52:18 PM »
the front bolt should be outward as far  as possible in the slot the rear  bolt should be inward as far as possible in the slot for max castor
Offline Katfish
  • 70 Challenger
« Reply #8 on: March 06, 2017 - 09:41:44 PM »
Set the washers to do this
« Reply #9 on: March 07, 2017 - 09:31:56 AM »
Don't tighten the bolts with the suspension hanging down.  Tighten them when the car is on the ground.  Otherwise you'll ruin the bushings.
