Author Topic: Wire ID for the headlight and dimmer switches on the dash of 1972 Cuda  (Read 759 times)
Offline George72Cuda
I am looking for any information on how to wire the headlight switch and the dash dimmer switch in a 1972 Cuda. I have no ideal where the wires go to from these switches. I would also be interested in any information on how to test these switches with an ohm meter.  Thanks
Re: Wire ID for the headlight and dimmer switches on the dash of 1972 Cuda
« Reply #1 on: March 07, 2017 - 10:17:37 PM »
diagram http://www.mymopar.com/downloads/1972/72BarracudaB.JPG
http://www.mymopar.com/index.php?pid=28
From Resident Expert Slotts RE: dimmer
Passing voltage is only part of it. The real test is by using an ohm meter and reading 0 on full bright with the dimmer switch, dome light on, headlights on and parking lights on. Any reading less than 0 ohms means resistance is present and are not producing the most amount of lumens possible.
« Last Edit: March 07, 2017 - 10:21:12 PM by Bullitt- »
