Gen III HEMI Stroker Question
Author Topic: Gen III HEMI Stroker Question  (Read 4127 times)
Offline DarthMeinholz
« on: March 08, 2017 - 05:13:08 PM »
If I wanted to take a 6.4L Gen 3 Hemi, either crate motor or out of a wrecker, and stroke it out, what parts would I need to buy/ upgrade in order to do so? I'm hoping to make around 600-650hp NA. I have a rough idea of parts, but want to make sure I'm not missing anything.
Compression Ratio: Want to run E85, 11:1?
Pistons: Manley Platinum Series Lightweight 2618 HEMI 6.4L Stroker -5cc Dish Pistons - Part of Stroker kit
Piston Rings: HHP MANLEY STEEL TOP RINGS - Part of Stroker Kit
Connecting Rods: HHP MANLEY FORGED H-BEAM RODS (ARP2000) - part of Stroker kit
Wrist Pins: ARP 2000 - Part of Stroker Kit
Main studs: HHP ARP Main Stud Kit (5.7L/6.1L/6.4L HEMI Engines) - 244-5400 - $175.95
MDS Delete Hole Plugs: HHP MOPAR Block Plug for MDS Solenoid Holes - Qty 4 - $47.80
Stroker Crank: HHP Manley 4340 Forged Crank 4.050" stroke - $3170 - Part of Stroker kit
Cam bearings: Stock? If worn have machine shop replace.
Rod Bearings: Manley "H" Series narrowed rod bearings - Part of Stroker Kit
Main Bearings: Manley "P" Series main bearings - Part of Stroker Kit
Valves: ?
Springs: -Part of HHP Cam Perf Package
Retainers: -Part of HHP Cam Perf Package
Pushrods: HHP Manley Strengthened Pushrods for VVT 5.7L and 6.4L [.080 or .120 wall?] - $174.95
Crank Bolt: Stock, HHP Mopar Crankshaft Bolt 14mm Thread (5.7L/6.1L/6.4L HEMI Engines) - 6506340AA - $9.95
Cam bolt: Stock, HHP Mopar Cam Bolt (5.7L/6.4L HEMI Engines) - 6102430AA - $3.95
Oil pump: Stock
Head Gaskets: HHP Mopar OEM HEMI Head Bolts & Head Gasket Set - BLTS-GSKT - $192.95   -Part of Cam Perf Package
Head bolts/Head Studs: Stock, -Part of Head Gasket Kit
Timing Set: Stock?
Cam: HHP Comp Cams Hemi Phaser "266" Limiter Camshaft (VVT 5.7L/6.4L HEMI Engines) - 201-424-17 Needs Phase Limiter($87)*
New lifters: Stock, if worn use: Gen3 Performance Heavy Duty Non-MDS HEMI Lifters, Qty 16 w/ Trays - $539.95
Rocker shafts: Stock
Intake Manifold: Ported Stock - $325 OR – MMX HEMI Performance Intake by OCPerformance - $1,108.99
Cylinder Heads: stock 6.4L Apache? OR HHP Thitek CNC Ported - 2.125" Valve Heads - 100-1025- $2,799.99
Throttle Body: MMX 6.4L SRT CNC Ported Throttle Body 87mm - $349.99
Manifold Gaskets: Cometic 5.7L/6.4L Intake Manifold Gasket Set - $20
Exhaust Gaskets: Stock, Exhaust Gasket 6.1L/6.4L - $40
Front Main Gasket: ?
Rear Main Gasket: Fel-Pro BS 40684 Rear Engine Main Seal Set - $28.78
Windage Tray/Pan Gasket: MOPAR Oil Pan Gasket (aka Windage Tray) 2011-2014 6.4L - 5038377AA - $58.95
Front cover gasket: Stock, HHP Mopar HEMI Timing Cover Gasket (5.7L/6.1L/6.4L HEMI Engines) - 53021521AD - $12.95
Oil Pan: Milodon Oil Pan Kit: - $668.95
   -#31000 Milodon Oil Pan
« Last Edit: March 08, 2017 - 07:12:53 PM by DarthMeinholz »
