Author Topic: Balancing a 1973 340  (Read 1473 times)
Offline Cudatime
« on: March 10, 2017 - 09:47:58 AM »
Hello everyone, looking for some technical help!
My buddy and I are putting together a pretty much stock 1973 340 small block and I am confused on the whole balancing issue. There is so much info between the 340/360s when it comes to internal vs external and so on. Here is what I have:
Block # 2780930-340-S
Crank # 3462387
Balancer # 3751160
Rods # 2899495
I bought this engine tore down. The block, balancer, and crank are the original parts. The balancer does say "Use with cast crank 340" on it.
I realize this is a cast crank, externally balanced engine. It will have a 904 behind it. I did not get a flex plate with the engine. What do I need for a flex plate? What do I need for a torque convertor? Thanks!
Offline 1 Wild R/T
Re: Balancing a 1973 340
« Reply #1 on: March 10, 2017 - 11:37:44 AM »
This flex plate allows you to use a zero balance convertor...
https://www.summitracing.com/parts/BMM-10235/
Offline Cudatime
« Reply #2 on: March 10, 2017 - 03:50:36 PM »
Thank you. I see it is listed for the 727 but has two different bolt patterns so it must also work for the 904?
« Reply #3 on: March 10, 2017 - 04:31:07 PM »
There are separate part #s for a 360/904 and 360/727 so I assume they are different.  I don't see a 340/904 listed. :dunno:
http://www.jegs.com/p/B-M/B-M-Flexplates/748012/10002/-1
« Last Edit: March 10, 2017 - 04:40:37 PM by burdar »
Offline 7212Mopar
« Reply #4 on: March 10, 2017 - 06:47:12 PM »
My car has the original 904 and the original 318 was replaced with a 71 340. The 340 has a steel crank and internal balanced with matching dampener. There is no weight attached to the flex plate and converter. The flex plate appears to be a regular 340 flex plate with four fingers for bolting to the converter. It is not the round 360 type. I am not sure if there are differences between SB 904 and 727.
1973 Challenger Rallye, AT with 1971 340
2012 Challenger SRT8 392 YJ,  6 spd
Offline Cudatime
« Reply #5 on: March 10, 2017 - 09:52:00 PM »
Thanks guys. I gave TCI Transmissions a call today and the service man knew exactly what I needed. I need a weighted flywheel and a neutral balanced torque convertor for my externally balanced 340. Thanks again.
Offline 7212Mopar
« Reply #6 on: March 10, 2017 - 11:24:17 PM »
Flywheel for automatic? Is TCI talking about the ring gear for the Starter? I see some of their torque converter has the ring gear and some don't.
Offline Cudatime
« Reply #7 on: March 12, 2017 - 03:34:44 PM »
Sorry, I meant flex plate not flywheel.
« Reply #8 on: March 17, 2017 - 01:40:42 AM »
Depending which converter you use the 10 or 11 " use a different flexplate so you hve to pick the converter first and match the bolt pattern
