« Reply #3 on: March 12, 2017 - 07:30:58 PM »
remove high spots
clean real good both surfaces
turn valve cover upside down.
lay bead of RTV on cover
place gasket
lay bead of RTV on gasket or head seating surface
place valve cover on engine, and tighten down half way
let sit for 3 hrs
tighten down all the way
don't run engine for 24 hrs
this is the only method that has worked for me, as surfaces are not perfectly
flat on my covers.
I use the gaskets from Mancini
« Last Edit: March 13, 2017 - 01:42:36 AM by cudabob496 »
Logged
2011 Kawasaki Z1000
