I have a stroker 520" 6 bbl with 440 source heads with big valves and 11:1 compression pistons., roller rocker, roller lifters. I have a stock type distributor set up by FBO. My basic understanding it that I want to get as much advance with out detonation. I only have so much degrees to work with to get it started and to get it fully advanced at higher RPM. If I pull out advance, then I am losing some on the higher RPM, but I can get it to start easy. If I advance it so it runs out, then its hard to start. Am I wrong? If I change my springs, then I am only changing the RPM at which it starts to advance, right? Different springs can let me start the advance a little earlier or a little later in the rev range? Am I supposed to match it to when my outboard carbs open up? Or just before?
This controller is set to allow the car to start with little advance, and then moves to normal at idle. As RPM comes up, it knows which cylinder is the one that is predetonating, then retards the timing on that particular cylinder until the ping goes away. At that point, it increases the timing again per cylinder. Not overall. Its ability to "hear" the ping is adjustable. I have read some about it, and have heard great things, and I hear from the nay sayers.
I would love to get it set up where it just runs perfect all the time, but weather, temperature, gas, and weight in the car all change the dynamics of the timing. But the vintage distributor is set to where it is set. Sometimes it is perfect with just me in the car. Then if I grab a buddy and go for a beat run, it starts to run like crap because I needed to retard the timing a degree or two because the car now weighs 200 lbs more. I am not going to do that every time I want to run it hard. I was hoping the computer could help me out, and save my pistons, and bearings from a beating when it isnt just perfect. Plus, I want it to run hard when it can. I could set the all in at 33 degrees, but I feel like I would be losing out on the power that a couple extra degrees could give. I not afraid to try to fix the distributor, and I would love to have somebody make some recommendations on settings. First I need to know where to get an assortment of springs? My settings are close, just not perfect for every situation. My car isnt totally out of tune and I want this to save me from making it better. I just want it better than a stock type vintage distributor can do for me.
Hey Goody, if you have knock sensors and have to dial it back, why do you think that this unit won't do what the factory system you are using is doing? I am sure there is noise in my engine, but I was hoping my roller valve train my take some of the noise out. This unit is programmed to listen for a knock just after each cylinder firing. And it is adjustable to noise sensitivity.
