Author Topic: 72 Cuda Clutch over spring question  (Read 1479 times)
Offline William H Meister
  • And so it begins...
« on: March 16, 2017 - 07:19:37 PM »
Hi all:
The diagram I have shows the coil side of the spring in the pedal box and the rod end attached to the pedal. I can't seem to install mine that way. It does go together in reverse. Can anyone confirm that the service diagram is wrong before I install my pedals again?  Thanks in advance.  Bill
Offline Mpdlawdog
Re: 72 Cuda Clutch over spring question
« Reply #1 on: March 17, 2017 - 01:54:19 PM »
 :popcorn:
I have to put mine together as well.....
Offline 73440
« Reply #2 on: March 17, 2017 - 04:41:46 PM »
Is this the spring that brings the pedal back up, my pedal only returns about halfway up and have to use  the top of the foot under to finsh up if I want.
Maybe mines on wrong, have to look at how its attached.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline Fern
« Reply #3 on: March 17, 2017 - 08:21:40 PM »
Over center spring helps to pull the clutch pedal to the floor to make it easier to depress. It Dosent bring the pedal back up. If the pedal is not returning back up, maybe the clutch dosent have enough force to return the pedal. If a diaphragm clutch is used then the over center spring needs to be removed or the pedal will stick to the floor.
Offline 73440
« Reply #4 on: March 17, 2017 - 10:01:16 PM »
Thanks for that info, I was thinking backwards .
Not sure of the clutch type.
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
« Reply #5 on: March 17, 2017 - 10:05:09 PM »
It does over centre.  :2cents:
Offline Fern
« Reply #6 on: March 18, 2017 - 06:35:00 AM »
Correct.
When the pedal is past the 1/2 way point back up it does.
Offline 73440
« Reply #7 on: March 18, 2017 - 08:38:38 AM »
Thanks, gonna try to look at it today to get this straightened out.
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
« Reply #8 on: March 18, 2017 - 12:18:13 PM »
Thanks for the interest in the thread...If anyone can post a pick or knows how this is installed  :clueless:that would be helpful.
Bill
Offline jhaag
« Reply #9 on: March 18, 2017 - 01:07:06 PM »
Can't confirm either way but a quick look at Alan's web site turns up the photo below. Common sense says if it only goes on correctly 1 way, do it.  :2cents:
love 70 Challengers
Offline 73440
« Reply #10 on: March 19, 2017 - 06:58:28 PM »
Just took this photo.
I adjusted the fork rod and now the pedal is fully returning .
Now for the test ride.
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
