Author Topic: 8 3/4 vs D60  (Read 1084 times)
8 3/4 vs D60
« on: March 19, 2017 - 05:39:02 PM »
Various threads involve a decision between the 8 3/4 and the dana 60. What makes the dana stronger? Is it the differential? The case? The bolts holding it together?
 :dunno:
Offline 1 Wild R/T
Re: 8 3/4 vs D60
« Reply #1 on: March 19, 2017 - 07:34:03 PM »
The gears are bigger, the spiders are bigger, it was designed for a 3/4 ton or 1 ton truck... It's big beefy & heavy... But it uses more horsepower to drive than an 8.75  because of the angle of the gear teeth between the ring & pinion....
Offline rUNCHARGER
Re: 8 3/4 vs D60
« Reply #2 on: March 20, 2017 - 02:10:00 PM »
The housing is much stronger and doesn't deflect under shock load like an 8 3/4 does. And just bigger everything, The 8 3/4 is great for what it was engineered for, the Dana 60 was over engineered for a heavier application than the 8 3/4. The Dana 60 is 50 lbs heavier than an 8 3/4 and people say it takes more power to turn but I have seen a few tests that swapped between them and the ET's were the same.
Sheldon
Offline RCCDrew
Re: 8 3/4 vs D60
« Reply #3 on: March 31, 2017 - 09:28:56 PM »
I have never destroyed an 8 3/4. But I have killed several Dana 60s and 9 1/4s. Those axles were under big power trucks. I prefer the 8 3/4 for simplicity and easy gear swaps!!
Re: 8 3/4 vs D60
« Reply #4 on: April 08, 2017 - 08:12:02 PM »
the design is stronger in every respect  I have broken  bunch of 8 3/4 diffs cost the same to build either so unless you re swapping gears regularly I would use the Dana  :2cents:
Re: 8 3/4 vs D60
« Reply #5 on: April 08, 2017 - 09:00:16 PM »
I'm not arguing a d60 is stronger, just curious what EXACTLY makes them stronger.  :dunno:
