Author Topic: LA 360 - Metal PCV valve part number?  (Read 584 times)
Offline GoodysGotaCuda
« on: March 21, 2017 - 04:08:41 PM »
The plastic PCV valve on my Warlock has a terrible squeaking sound at high vacuum. If I pull it from the valve cover while running, the check back is visibly resonating.
I replaced the previous PCV valve about 2 months ago and the new one is doing the same thing. I have replaced the line to the back of the carb, no improvement.
Is there a metal version for the stock grommet that I can try?
Thanks
1976 Dodge Warlock
Wheel & Tire Specs:Link
Re: LA 360 - Metal PCV valve part number?
« Reply #1 on: March 21, 2017 - 05:30:53 PM »
not seeing metal for 76..
If you look at Rockauto plenty under pre-70 smallblocks  that should work but I really don't know
look at STANDARD MOTOR PRODUCTS V180
http://www.rockauto.com/en/moreinfo.php?pk=50428&jsn=72
http://www.rockauto.com/en/catalog/dodge,1968,dart,5.6l+340cid+v8,1087769,exhaust+&+emission
« Last Edit: March 21, 2017 - 06:06:51 PM by Bullitt- »
