engine bay colors
Author Topic: engine bay colors  (Read 6964 times)
Offline gomangoRT/SE
Re: engine bay colors
« Reply #15 on: August 05, 2005 - 08:44:36 PM »
Ok, I am now leaning to painting the front of the cowl black...........is this semi gloss black and does anyone have a correct PPG or Dupont number black that would be correct...........or what about this
SEM trim black??
Offline FY1 RT SE
« Reply #16 on: August 05, 2005 - 08:50:49 PM »
SEM trim black??
Same color as the radiator blackout.
Offline loco340cuda
« Reply #17 on: August 07, 2005 - 07:12:01 PM »
That's a cool document, looks like the date says it was one of the pre build engineering prints, I don't think I've ever seen one painted with just the inner fenders blacked out in the engine compartment but the rest I have. Am I reading the print wrong or is it showing the blackout in the engine compartment inner fender? Where did you get such a collectable document? Pretty neat.  :grinyes:
plum6pak,  I think your not looking at the document quite right.  The engine compartment is not blacked out, if you notice the crosshatch is different there denoting that in reality what is blacked out is hidden from view in the angle that you are looking at.  So in real life if you were to look at the car from that angle you would not see the black out becuase it is on the otherside of the sheet metal.  Look at the radiator support and you will see the same thing, the part that is under the header panel is cross hatched differently then the part that you can actually see in real life.  Hope that made sense.   :)
1970 Cuda 340 4-speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
Offline Tropicalcats
  • Don't Ever, Ever Give Up
« Reply #18 on: August 07, 2005 - 07:33:16 PM »
I think most are black due to repainting a car, and not pulling the engine...easier to black-out the compartment that to paint around the engine...
How is it easier to black out the compartment than paint it the body color with the engine in the car?
SOLD
Offline Plum6Pak
  • Plum6Pak
« Reply #19 on: August 07, 2005 - 07:51:14 PM »
 :thumbs:  :grinyes: OIC!  Yes it does make sense now! Thanks!
