Author Topic: 72 challenger wont shut off with key.  (Read 1280 times)
Offline moparman72
« on: March 24, 2017 - 10:12:26 PM »
recently got my 72 dodge challenger fired up but it will not shut off with key. tried new ignition switch and it will still not shut off I have to pull the coil wire.
Offline TelisSE440
Re: 72 challenger wont shut off with key.
« Reply #1 on: March 25, 2017 - 04:29:58 AM »
Ok that's a weird problem IMHO. The first thing i would check, would be the blue wires to the ballast resistor if they have current when the ign switch is off (it shouldn't have any), but don't do this test after you've started and shut off the switch. Do it before, if it doesn't have current then turn on the switch, shut it off and then check again. If it has current before you turn the switch then somehow the blue wire has a short or is connected to a source providing it current. If it does this after then something must be wrong with the switch (but you've replaced it already). Good luck tell us what happened.
Offline moparman72
« Reply #2 on: March 25, 2017 - 05:01:30 AM »
will do thanks for the advice. I have two ballast resistors one for the coil I have and a ballast resistor on the fire wall that has four prongs on it.
Offline TelisSE440
« Reply #3 on: March 25, 2017 - 06:01:16 AM »
Check the prong in the firewall ballast resistor that has the blue and brown wires, check that and the exact opposite blue one. The single blue one feeds the opposite blue/brown one.
« Last Edit: March 25, 2017 - 06:03:06 AM by TelisSE440 »
Offline TelisSE440
« Reply #4 on: March 25, 2017 - 06:18:38 AM »
If the problem is there, it might then occur another problem, somehow more erratic but you should check that also. The brown wire (the one that goes to the firewall ballast resistor) goes to a prong that fits the bulkhead connector to the other side (of the wire). The connector has the brown wire just next to the big black wire that goes to the alternator. Now the years and possibly heavy current loads may have that black wire developing huge temps and if it touches the wires next to it, melts them and kind of merges them together so it gets the current from the battery (the black wire has current all the times unless the battery is disconnected). Seems a little complicated, but it's not. If the wires aren't merged, then maybe they are merged (and most possibly) to the inside of the bulkhead connector behind your pedal assembly next to the steering column.
« Reply #5 on: March 25, 2017 - 09:22:23 AM »
Stock ignition? Any rewiring going on?
If stock, somehow the blue wire is staying hot after you shut off with the key. Does your battery drain if you leave it for a while, or check the ballast resistor. Does it stay hot after you shut off?
« Reply #6 on: March 25, 2017 - 03:22:06 PM »
Thinking about the melt down we've witnessed in some harnesses in the bulkhead connector area... Possible the red & blue wire has shorted together.
I'd be checking if someone has added a jumper wire straight from the battery or starter relay as well before digging to deep in the factory harness.
Offline moparman72
« Reply #7 on: March 26, 2017 - 09:51:50 PM »
 it has accel super coil, Mallory dual point distributor It was a 318 car but it has a 383 in it now.
Offline 1 Wild R/T
« Reply #8 on: March 27, 2017 - 12:53:51 AM »
Some people complain about anything.... Usually it's "My car won't start...." This time it's "My car won't stop" :smilielol:
Offline TelisSE440
« Reply #9 on: March 27, 2017 - 01:04:15 AM »
Hadn't thought about it that way... :roflsmiley:
