Author Topic: Standard Gauge cluster Temp Gauge Issue  (Read 778 times)
Offline cv70chall
  • 1970 Challenger
« on: March 27, 2017 - 08:24:42 AM »
Recently had to replace head gaskets- one was leaking. Everything went back together fine, yet I now have an issue with my temperature gauge. I have a separate set of under dash gauges- and the water temperature reads consistently at 175-180.
The dash gauge usually would rise just to or past the first hash mark past "C", which was normal as well.
Since the engine work, the dash gauge now jumps past "H" and sits there. After the engine has been turned off, the gauge returns to normal. I checked the sensor at the motor and the wire had been accidentally cut- and I can't locate the end that runs to the firewall.
My thought is that the other end is either grounded (laying on a section of the engine or something else causing this, but I can't for the life of me seem to locate the end.
What color wire am I looking for for starters and where would it come out of the firewall- maybe I can trace it forwards.
Second, ever since the engine work, I now notice that the car will have trouble starting after it has been run for a while. Almost sounds like the car isn't getting fuel or a consistent spark. What should I check for here as well?
This was a "routine" head gasket replacement.
Thanks
Re: Standard Gauge cluster Temp Gauge Issue
« Reply #1 on: March 27, 2017 - 08:55:09 AM »
I believe that's the Violet wire coming out of #21 bulkhead connector seen in this diagram near bottom left.
http://www.mymopar.com/downloads/1970/70ChallengerA.JPG
Interestingly that is right next to the Brown "start" wire in #22 so I'm thinking possibly these were damaged during your head work.
Offline FY1Cuda
« Reply #2 on: March 27, 2017 - 12:22:01 PM »
The temperature sender wire goes along the top right side of the engine along with the wires to the alternator.  I would look behind the alternator to see if that wire got pinched (and cut).  Hopefully you didn't tighten down the head on top of the wire.
Offline cv70chall
  • 1970 Challenger
« Reply #3 on: March 27, 2017 - 01:24:21 PM »
Thanks!
I'm hoping it didn't get pinched by the head. Worst case- it stays there and I cut both sides, splice and move on.
Any idea if anyone sells the replacement press-on connector to the temp sensor wire?
