Author Topic: easier start mods  (Read 4044 times)
Offline citron fella
Re: easier start mods
« Reply #30 on: March 31, 2017 - 06:18:01 PM »
copy that i think there might be a spacer in there already i'll post pics in the a.m drive safe
1971 Dodge Challenger #matching 340 citron yella
Offline RCCDrew
« Reply #31 on: March 31, 2017 - 09:24:24 PM »
Subscribed
Offline jimynick
« Reply #32 on: March 31, 2017 - 10:24:00 PM »
You know, it may be a fuel issue, but if you don't eliminate the starter as an issue, you'll spend more time and money than may actually required. Just my  :2cents:
Offline Fern
« Reply #33 on: April 01, 2017 - 06:50:38 AM »
Had kinda same issue and changed to Shell V-power and also got a mini starter. Starts much better now.
Not sure if the brand of gas makes a difference but the starter does.
« Reply #34 on: April 01, 2017 - 09:00:22 AM »
https://www.amazon.com/gp/aw/s/ref=is_s_ss_i_0_7?k=carb+spacer&sprefix=carb+sp what would be best for my # matching  340? thanks drive safe
« Reply #35 on: April 01, 2017 - 10:16:13 AM »
Mini starter will spin things over faster with less amp draw. Although it doesn't sound like that is the core issue, it is a nice improvement. Get a rebuilt starter from your local parts house for an early 90s Dodge truck. Maybe about  $60.
Phenolic or wood spacer under the carb  help with  hot fuel bowls. $20-30 depending on source.
Auxiliary electric fuel pump mounted by  the gas tank. You don't need a huge one and can put it inline with your mechanical unit. A pushing pump is more efficient and it will overcome the fuel percolation that occurres at higher engine temps.  This has the added benefit of being able to prime the carb after car sits for a week or more before spinning it over to start. $60-100
Install a cool can between the mechanical pump and the carb. This can be a simple home made unit of a steel can with coiled fuel tube inside it. This aids in dissipating heat in the fuel after going through the lines near the exhaust and the mechanical pump on the block.  Homemade cost, about $10, or you can buy a big polyethelene  pre-fab unit for  $100.
« Reply #36 on: April 04, 2017 - 11:58:01 AM »
https://www.amazon.com/gp/aw/s/ref=is_s_ss_i_0_7?k=carb+spacer&sprefix=carb+sp the carburetor looks stock not aftermarket which one should i buy? thanks
« Reply #38 on: April 04, 2017 - 12:52:09 PM »
description
The Edelbrock Four-Hole Square-Bore to Spread-Bore Carburetor Adapter allows proper installation of carburetor to manifold. It mounts the Edelbrock square-bore carburetors to stock Quadrajet and Thermo-Quad manifolds. It is designed to replace the original equipment unit. It allows the use of almost any carburetor on almost any intake, saving the hassle and expense of purchasing all new components when changing carburetors or intakes.
« Reply #39 on: April 04, 2017 - 04:08:08 PM »
she's #'s matching and appears to have stock intake and carburetor. i really want to keep her as stock as possible she's just a once a week cruiser.
« Reply #40 on: April 06, 2017 - 10:51:35 PM »
I'm not the sharpest crayon when it comes to stock stuff. Assuming its a  square bore Carter, get this;
http://www.jegs.com/webapp/wcs/stores/servlet/SearchResultsPageCmd?Ntt=wood+carb+spacer&requestYear=&storeId=10001&catalogId=10002&langId=-1&year=&make=&model=&submodel=&engine=&Nrpp=&No=&persistYmm=false
It sits under the carb and won't be noticeable to any but the most  detail oriented inspection. You could paint the edges to match your intake to make it more discrete
Also get one of these and install by the fuel tank.  You can wire into a switched  connection in the fuse block so no additional switches to see. This is under the car where no one will see it unless they crawl around.
http://www.jegs.com/i/Autobest/035/12S/10002/-1
Will you be doing your own installation or will you be contracting it out? This is an afternoons worth of work if you are mechanically inclined and have some time turning wrenches on these cars. If you don't, expect  $200-500 for installation.
Offline xtopfuel
« Reply #41 on: April 07, 2017 - 03:42:37 AM »
You stil have not answered the questions so I assume you will be a parts changer , spend unnecessary money and if fixed you will not know what fixed it I asked if cranked slow, chargerdon asked, as I stated there is tremendous knowledge on this site an questions get asked for a reason good luck
« Reply #42 on: April 08, 2017 - 10:57:26 PM »
Try this they are extremely effective http://www.coolcarb.com/
