Author Topic: Mancini Front End Tool Kit  (Read 630 times)
Offline solarguy
« on: March 27, 2017 - 06:21:44 PM »
Getting ready to rebuild the front suspension and was looking at this  tool set,
http://www.manciniracing.com/unfrsuprotok.html     to ease the job.
It has been a long time  since I've rebuilt a mopar front end and I want to work smarter this time, not harder.  I already have a ball joint socket, pickle fork and universal type tie rod and pitman arm pullers in my box and was looking for feedback from anyone who found any of the tools in this kit useful.  Thanks.
Offline twalker
Re: Mancini Front End Tool Kit
« Reply #1 on: March 27, 2017 - 06:35:58 PM »
Looks like a great kit.
Offline 7212Mopar
« Reply #2 on: March 27, 2017 - 11:12:50 PM »
You need the ball joint socket and the bushing remove/installer if you are rebuilding the upper control arms. The rest you really don't need. You will need a press for the lower control arm bushing to remove and install. The metal bushing sleeve require some work to remove. Basically weld washer to the sleeve and use a press to remove.
1973 Challenger Rallye, AT with 1971 340
2012 Challenger SRT8 392 YJ,  6 spd
