Author Topic: dash light bar correct for rallye dash?  (Read 3443 times)
Offline culp71
« on: March 29, 2017 - 11:17:02 AM »
I have seen two different versions of light bar assemblies, one with 3 lights and three lens, and another with 4 lights and 4 lens, which is correct for 71 cuda rallye dash, would either fit and function on non-rallye or rallye dash setup?
unfortunately I was sold one and was told its for a rallye dash, but it has 3 lights.... now that I have it restored and ready to go in, I am questioning it.
« Last Edit: March 29, 2017 - 11:50:39 AM by culp71 »
Offline Fern
Re: dash light bar correct for rallye dash?
« Reply #1 on: March 29, 2017 - 11:37:25 AM »
4 light for rallye
3 light for standard
Offline culp71
« Reply #2 on: March 29, 2017 - 11:52:22 AM »
that's what I thought.....would it mount in the same manner to dash and function the same?
Offline 67vertman
  • Member since 9-23-2005
« Reply #3 on: March 29, 2017 - 12:12:38 PM »
Yes, they mount the same, but the 4 light one illuminates better.  i have a 3 light one on my ralley gauges it it work fine,
Offline culp71
« Reply #4 on: March 29, 2017 - 12:24:51 PM »
okay, thanks.
I just might add another or two lights, if too dark.
« Last Edit: March 29, 2017 - 12:30:00 PM by culp71 »
Offline culp71
« Reply #5 on: March 29, 2017 - 12:29:03 PM »
how about lens color, mine (non rallye) have a blue, but notice most rallye have green lens. what's the correct color?
did they change every few years or were they always the same, depending on rallye or not.
Offline Rich G
« Reply #6 on: March 29, 2017 - 01:55:01 PM »
The 4 light bar is a lot better on the rally dash. But the three light  will get you by . But you'll like it better if you find one.
« Reply #7 on: March 29, 2017 - 03:24:10 PM »
The lenses are blue but when light shines through them, it shows up green on the gauges.  If you used a more "white" bulb instead of a "yellowish" white bulb, my guess is the gauges would look blue.
« Last Edit: March 29, 2017 - 03:28:33 PM by burdar »
Offline Racer57
« Reply #8 on: March 29, 2017 - 03:36:58 PM »
Using these green LEDs instead of the standard bulbs with the factory blue lens looks great and you can still adjust the brightness.
http://www.ebay.com/itm/4X-Car-Ba9s-W6W-5050-5SMD-LED-Green-Interior-License-Plate-Map-Dome-Lights-GH2-/380962523256
Offline 1 Wild R/T
« Reply #9 on: March 29, 2017 - 04:44:23 PM »
And I use these with the lens & it's way brighter than it needs to be....  Thankfully the dimmer still works..
https://www.amazon.com/gp/product/B018LUUON8/ref=od_aui_detailpages00?ie=UTF8&psc=1
Offline Lbs
« Reply #10 on: March 29, 2017 - 11:46:40 PM »
I used the same bulb as racer57 and they work great and like 1 wild R/T says, the dimmer works. This is what it looks like with the LEDs
Sent from my iPad using Tapatalk
Offline mjb765
« Reply #11 on: March 31, 2017 - 08:30:18 AM »
Tha looksgreat...just ordered the  bulbs.  :bananasmi
Offline Racer57
« Reply #12 on: March 31, 2017 - 09:21:37 AM »
The LEDs can be a little tight going into the holes. They will fit though. Also, do not twist them any harder than needed. The LED portion isn't as secured to the base as a regular bulb is.
Offline mjb765
« Reply #13 on: March 31, 2017 - 06:40:15 PM »
Thanks for the info.....now all I have to do is remember by the time I do the swap!!
Offline Racer57
« Reply #14 on: March 31, 2017 - 10:04:32 PM »
I made it sound worse than it is. :D  Keep in mind that your existing light sockets are old and probably have a little corrosion on them. Use Dielectric grease on them and there will not be any issues.
