Author Topic: Need serious help and advice!  (Read 4533 times)
Offline cudabob496
Re: Need serious help and advice!
« Reply #30 on: April 09, 2017 - 01:26:06 PM »
Just an FYI. I have an original 440 car and it came with a 22"rad. It is now stroked and has a 195 degree thermostat for the 6 pack and does not overheat. Oh it is a copper rad.
on a 90+ degree day, and it doesn't overheat?
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
« Reply #31 on: April 10, 2017 - 12:21:04 AM »
Cool! Can you post a pic of the oem radiator setup? A RB engine with the 22" radiator is apparently a rare option. :thumbsup:
Offline mopar jack
« Reply #32 on: April 10, 2017 - 09:47:25 AM »
I have two big block cars with a 22 inch rad. A 1970 Chrysler 300 with a 440 and 22 inch radiator with no shroud. That would be the 350 H.P. motor and that is what's in my Barracuda now after I added a shroud. I also have a 71 Road runner 383 with a 22 inch  radiator that came with a shroud all stock.
Offline mopar jack
« Reply #33 on: April 10, 2017 - 10:03:48 AM »
This is my Barracuda set up that came from a 70 Chrysler. I had to make a small adjustment to the mounting bracket to bolt in the E body. I added some home made brackets to mount a shroud and I added the viscous drive fan. It originally came with a fixed fan.
Offline mopar jack
« Reply #34 on: April 10, 2017 - 10:13:40 AM »
This is the road runner mostly original 22 inch rad with shroud and solid fan.
Offline 734406pk
  • Andy
« Reply #35 on: April 10, 2017 - 10:35:50 PM »
Thanks for posting the pics! It would seem that a fixed fan may work w/o a shroud but a viscous fan would require one? The two shrouds look identical between the two cars. Same radiator?
« Last Edit: April 10, 2017 - 10:37:38 PM by 734406pk »
Offline mopar jack
« Reply #36 on: April 10, 2017 - 11:14:52 PM »
The Road runner shroud is original and the Barracuda is a reproduction. The radiators are very close only difference is the  bracket that mounts to the car
Offline 734406pk
  • Andy
« Reply #37 on: April 10, 2017 - 11:29:18 PM »
They both fit nicely!
