Author Topic: Pinion snubber... something missing ?  (Read 1343 times)
Offline Racer57
« on: April 01, 2017 - 10:22:27 PM »
There is a 3 1/2" gap between the top of snubber and floor. Is there suppose to be something bolted in the hole that the snubber would hit ?
Re: Pinion snubber... something missing ?
« Reply #1 on: April 01, 2017 - 11:56:38 PM »
Nope
Offline mopar jack
« Reply #2 on: April 02, 2017 - 12:08:45 AM »
only thing missing are some sticky tires, 400 plus pounds of torque and a hard launch to reduce the gap! :)
Offline 69bcuda
« Reply #3 on: April 02, 2017 - 11:43:59 AM »
IMO, All the stock snubber does is keep the yoke from digging a hole in the floorboard as you fly over dips in the road while weight is loaded in the back seat or trunk. You'll likely need an adjustable (and maybe floor reinforcement) to help control axle windup at the track.
Offline 73sixpack
« Reply #4 on: April 02, 2017 - 11:54:25 AM »
The Mopar Preformance adjustable snubber was too tall to work on my car, I think they are for cars with Super Stock springs that have more arch. I made a snubber for mine with about an inch of clearance, so it would hit sooner and load the tires (slicks) harder without as much spring wrap.
« Reply #5 on: April 02, 2017 - 01:12:17 PM »
Dana 60 cars require an additional plate welded in to lower the contact point.
Which rear end do you have?
Offline SBDave
« Reply #6 on: April 04, 2017 - 04:58:20 PM »
I assume that 3 1/2" gap is with the car on it's tires, full of fuel, interior installed etc
In general what would be a good distance for a street driven car that is not drag raced?  I've got "flat" leaf springs to help with handling and I wonder if the pinion snubber bushing is too close on mine.  I remember the pinion snubber being a part of a metal plate that bolted to the top of the rear end, are there different height bushings?
« Reply #7 on: April 04, 2017 - 05:54:27 PM »
Do you have a picture or link that show that?  :clueless:  Mine is so close now that when I have people in the back seat it bottoms out, fine with just me or a passenger in the front seat.
« Reply #8 on: April 06, 2017 - 12:12:27 AM »
Never heard of that.  You sure?
Offline Racer57
« Reply #9 on: April 06, 2017 - 08:46:25 AM »
8 3/4 rear end.
