Author Topic: 71 cuda gauge hi beam tube  (Read 1512 times)
Offline culp71
« on: April 11, 2017 - 11:42:46 AM »
where can one find the hi beam tube used on a 71 cuda for the back of the gauge?
Offline JayBee
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline mjb765
Re: 71 cuda gauge hi beam tube
« Reply #2 on: April 11, 2017 - 04:14:32 PM »
Those sets of 3 are for the indicator lights. The high beam tube is square and more difficult to find. I just bought one from Mike at BE&A, but I am not sure if he has another one. Give him a call.
Offline AARTA340
« Reply #3 on: April 11, 2017 - 05:24:48 PM »
I am traveling and probably have one so not much help, but I would suggest as mjb765 did, and check with either Mike at BE&A or Dave at ROseville.  :cheers:
Offline JayBee
« Reply #4 on: April 11, 2017 - 06:14:18 PM »
Good catch mjb765, I need to read closer.
John
2014 Toyota Avalon
Offline mjb765
« Reply #5 on: April 11, 2017 - 09:29:35 PM »
I had called Mike and he said I could get it anywhere and I was like "the square high beam tube"??  then he said "OH, that one"........Everyone seems to forget that one until you need it.
Offline culp71
« Reply #6 on: April 12, 2017 - 10:35:25 AM »
anyone have a good picture of one?
if I knew what it was to look like I would just make one.
Offline JayBee
« Reply #7 on: April 12, 2017 - 06:11:31 PM »
I believe I sent you this in another one of your threads. It's the only picture I have of it. The front will have 2 positioning/aligning tips that go into the two holes at the top of the speedo and the housing should have a square gasket for the back of the tube.
John
2014 Toyota Avalon
Offline AARuFAST
  • AARuFAST
« Reply #8 on: April 12, 2017 - 08:44:02 PM »
You could probably make one with a 3D printer.............
1970 AAR Cuda
" I Want to Ride "
it was the most boring
2 minutes of my life!!!!"
Offline culp71
« Reply #9 on: April 13, 2017 - 10:24:50 AM »
JayBee:
you did, and thank you, cause that's the only picture I could find, but was curious about what the front looked like, you explained that well enough too, I will make up my own. is there a lens at the front end of tube or just wide open?
trying to get everything in gauges an in/ on dash before I install it all and this is the last thing of uncertainty.
« Last Edit: April 13, 2017 - 10:34:46 AM by culp71 »
Offline JayBee
« Reply #10 on: April 13, 2017 - 11:20:56 AM »
JayBee:
Not a lens so to speak, it's more of small square colored plastic film over the opening. I'll try and find some time to take that cluster apart again and get you more pictures. Pretty busy, new kitchen countertop and family Easter stuff on Friday plus Sunday.
John
2014 Toyota Avalon
Offline JayBee
« Reply #11 on: April 13, 2017 - 01:23:05 PM »
Found time, countertop is late getting here.
Gasket
Colored film. It looks brownish but displays bright read when the bulb is on. I added scotch tape to keep it in place.
John
2014 Toyota Avalon
Offline culp71
« Reply #12 on: April 13, 2017 - 02:17:16 PM »
awesome, many thanks. :bananasmi
Offline chargerdon
« Reply #13 on: April 23, 2017 - 05:18:11 PM »
What about for a standard dash...   what goes in the holes to cover the bulbs for the High Beam, Low oil pressure, and parking brake lights ???
