Author Topic: which distributor for 440-6 with MSD 6AL  (Read 4022 times)
Offline 351c4v71
« on: April 14, 2017 - 07:10:30 PM »
Hi guys,
I just bought an MSD 6AL wanting to upgrade from my orange box and old distributor (#3690432).
I have a 71 cuda clone with 440-6 mild cam stock heads and headers. This is for street use.
Which distributor would be an upgrade from the old one and fit easily with MSD 6AL?
Should I get with the vaccuum advance? I read about the MSD #8546 but it doesn't have vacuum adv and I think it needs an additional connection for the tach...
I don't want to spend more than the #8546 (320$).
Your recommandations are welcome, thanks!
JS
Montreal
Offline angelo78
Re: which distributor for 440-6 with MSD 6AL
« Reply #1 on: April 14, 2017 - 08:10:07 PM »
I run the msd pro billit with no issues but i did require the tach adapt box.  There is a electronic conversion that you can do to the tach which i wish i did.  Then youre tach will be accurate as well.
Offline 734406pk
  • Andy
« Reply #2 on: April 14, 2017 - 09:52:46 PM »
I am running the MSD Pro Billet distributor, no issues at all!
Offline xtopfuel
« Reply #3 on: April 15, 2017 - 09:35:07 AM »
Offline Beekeeper
« Reply #4 on: April 15, 2017 - 11:00:35 AM »
Hi guys,
JS
Montreal
JS, I ran the same box and one of these distributors in my 64 Vette. It was an amazing change. I cringed at the price initially but now I see it as money well spent. I am definitely doing this in my 70 Challenger when the engine goes back in. The engine fires up hot or cold in a fraction of a second and idles beautifully without ever loading up at idle.
By the way, for some reason on the Vette, it always tried draining the battery with key off and I hooked it up precisely as the instructions advised. In the end, I put a battery disconnect on it and life is good. I can go over a month with zero drop in voltage.
Offline 351c4v71
« Reply #5 on: April 15, 2017 - 07:39:13 PM »
Looks like most guys use an MSD pro billet when they have an MSD 6AL. But i think there are two, one with the vacuum advance and the other wihout. Which one is best suited for street use?
Offline 734406pk
  • Andy
« Reply #6 on: April 15, 2017 - 08:54:13 PM »
The MSD distributors with the vacuum advance are "Ready to Run" type and don't need a 6AL. The amplifier is inside the distributor with these RTR units. The Pro-Billet distributor is mechanical advance only as far as I know. This type needs a 6AL since it's a trigger only distributor.
Offline Beekeeper
« Reply #7 on: April 15, 2017 - 09:12:05 PM »
Mine has a vacuum advance but still needs the box. I never run vacuum advance and I love it. Other guys will probably disagree but I tend to think of them as smog equipment. I set my engines up to have no more than 36-38 degrees of total advance. This distributor is very adjustable (and super easy) on how much mechanical advance you can run. Factory setting is 20 degrees (I think) and I dial in the initial advance around 16 degrees. No issues whatsoever and it works great.
If I ran the vacuum advance, I would be forced to reduce the initial advance down to 4-6 so that I wouldn't get too much total advance. I have played around with it many times but I always come back to running no vacuum advance and it's runs better, runs stronger, starts easier, idles better, etc.
Offline 734406pk
  • Andy
« Reply #8 on: April 15, 2017 - 09:29:50 PM »
Quote: I have a 71 cuda clone with 440-6 mild cam stock heads and headers. This is for street use.
The base timing is mainly determined by your cylinder pressure at idle speed. Do you know what your lift/duration specs are for your camshaft?
Offline 351c4v71
« Reply #9 on: April 16, 2017 - 05:01:04 PM »
The cam in it is very mild, it's a 270H comp cam:
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=700&sb=2
This is the distributor I have now and want to upgrade to fit with my MSD 6AL that I'm about to install:
https://www.summitracing.com/int/parts/dcc-3690432/reviews/
It has the vacuum advance and needs the orange box.
I'm trying to learn here because I still know very little. An accountant trying to understand his mopar you see!
2 things I don't get #1 = why do I need a convertor box for my rallye dash tach to work if I install MSD 6AL and pro billet distributor? I have the orange box and regular vac adv dist now and no need for a special convertor box.
#2 = 734406pk, you're saying that if I have a vac adv dist then no need for MSD box...but I need the orange box?why? And yes they do make RTR pro billet msd, found it at summit's link.
https://www.summitracing.com/int/parts/msd-8387
Can I use the accell coil I already have with this pro billet MSD set-up or do I need to change that to MSD as well?
Thanks :pullinghair:
« Reply #10 on: April 16, 2017 - 10:31:08 PM »
I run a Mopar Performance dizzy with the MSD. Seems to work fine. What advantages does the MSD pro-billet give you over the MP piece?
Offline 351c4v71
« Reply #11 on: April 17, 2017 - 01:40:18 PM »
dodj, not sure what the advantages are. But all the guys whi responded to my post said they were using the MSD pro billet.
So you run the MAS 6AL box , correct? with a mopar dist? Does your original tach work and did you need a special convertor box for it?
I'd like to start with such a set-up before dishing out the dough for a pro billet.
Thanks
Offline HP_Cuda
  • Mopar or No Car!
« Reply #12 on: April 17, 2017 - 02:21:34 PM »
MSD 6AL and Pro Billet - easy setup and good combo. (Well as long as the box stays alive).
The only time you need a converter is if you are using an older tach you will need the adaptor to make it work.
That's it!
Offline 351c4v71
« Reply #13 on: April 17, 2017 - 07:26:03 PM »
hp_cuda
What do you consider an old tach? Is the original tach in my 71 barracuda rally dash "old" ?
Offline xtopfuel
« Reply #14 on: April 17, 2017 - 07:33:35 PM »
47 years old
