Author Topic: K frame bolt  (Read 1319 times)
Offline Tantster
K frame bolt
« on: April 17, 2017 - 10:26:35 PM »
Looking for 1 bolt to replace this one.
Re: K frame bolt
« Reply #1 on: April 18, 2017 - 09:14:25 AM »
That one should still work.  When the K-member is tight, the threads closest to the head of the bolt will be engaging the nut inside the frame rail.  You have bad threads on the upper part of the bolt because that section was sticking up through the nut and was exposed to the elements.  You can chase the threads on the upper part of that bolt if you need to.  All you need it to do is engage the nut. It won't be doing anything once the K-member is tight.
« Last Edit: April 18, 2017 - 09:17:05 AM by burdar »
Offline mopardave
  • Sponsor
    • rosevillemoparts
Re: K frame bolt
« Reply #2 on: April 18, 2017 - 05:49:36 PM »
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline Tantster
Re: K frame bolt
« Reply #3 on: April 19, 2017 - 08:44:30 AM »
Thanks for the responses, going to stop by a local Mopar salvage yard in Selma to see if they have a decent one. If not them I'll give you a call Dave.
Offline crocha617
Re: K frame bolt
« Reply #4 on: April 19, 2017 - 10:12:43 AM »
I'm sure I have several extras I can send you one for price of postage if you can't come up with one locally.
