Author Topic: At a loss why my brakes suck  (Read 4194 times)
Offline TonyBolton
Re: At a loss why my brakes suck
« Reply #15 on: April 23, 2017 - 12:38:18 PM »
Old car show pic I zoomed in on / screenshot...
Offline TonyBolton
« Reply #16 on: April 23, 2017 - 12:39:15 PM »
Don't be jealous of my heater core bypass hose.  8)  :-*
Offline 1 Wild R/T
« Reply #17 on: April 23, 2017 - 02:21:57 PM »
Does your booster check valve have an extra nipple? If it does attach a vacuum gauge there & see what you've got....   OE master is 1.125 I'm sure Cass didn't sell you a bigger bore M/C... I think having the vacuum pump in the trunk is marginal & having the reservoir back there is worse.... I've always mounted the reservoir off the diagonal brace under the fender....As far rearward as you can get it to maximize tire clearance...
Offline TonyBolton
« Reply #18 on: April 23, 2017 - 03:09:26 PM »
No leaks.....the pump kicks on and off and stays off at its preset range. On at 15 off at 20 I believe
Sent from my SM-G930R4 using Tapatalk
Offline 1 Wild R/T
« Reply #19 on: April 23, 2017 - 06:27:03 PM »
Yeah, at the back of the car, put the gauge on the check valve at the booster..... :2cents:
Offline TonyBolton
« Reply #20 on: April 23, 2017 - 06:28:04 PM »
If it was leaking at the booster.....wouldnt it show at the back as well?
Offline 1 Wild R/T
« Reply #21 on: April 23, 2017 - 06:36:55 PM »
Put a gauge ion it.... :2cents:
Offline Beekeeper
« Reply #22 on: April 23, 2017 - 08:13:24 PM »
I'm curious as well to see what the vacuum is at the booster.
Offline xtopfuel
« Reply #23 on: April 23, 2017 - 09:13:05 PM »
I agree I don't think you have enough vacuum at booster
Offline Beekeeper
« Reply #24 on: April 23, 2017 - 09:43:11 PM »
Is vacuum signal something that lessens over long runs? We see drops in voltage when we have long wiring runs with wire that's too skinny. I've never run a long vacuum line but I'm just curious if you can have a similar drop in signal strength over an unusually long run.
Offline 73440
« Last Edit: April 23, 2017 - 10:01:04 PM by 73440 »
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline 1 Wild R/T
« Reply #26 on: April 23, 2017 - 10:08:14 PM »
http://www.mbmbrakeboosters.com/index.php?option=com_content&view=article&id=12:what-to-do-if-you-suspect-your-brake-booster-is-not-working&catid=7:diagnosing-brake-system-problems&Itemid=15
http://www.engineeringtoolbox.com/vacuum-pipe-line-pressure-drop-d_1197.html
Thank You....  Now if they would just show smaller line sizes....
"Is vacuum signal something that lessens over long runs? We see drops in voltage when we have long wiring runs with wire that's too skinny. I've never run a long vacuum line but I'm just curious if you can have a similar drop in signal strength over an unusually long run."
Yes.... Reason why I asked early on about hose size.... To move the vacuum pump and reservoir 15 feet from the booster he needs at least 1/2" ID hose & 5/8" would be better....  Moving the reservoir closer and leaving the pump in the trunk will help but still isn't ideal.....
Offline Beekeeper
« Reply #27 on: April 23, 2017 - 10:50:27 PM »
Thanks for answering my question. Good to know for future projects.
Offline 1 Wild R/T
« Reply #28 on: April 30, 2017 - 12:15:41 AM »
Well? Did you put a gauge on it yet?
Offline xtopfuel
« Reply #29 on: April 30, 2017 - 06:37:22 AM »
good question, status?
