Author Topic: Broken exhaust manifold stud  (Read 2907 times)
Offline 73440
« on: May 06, 2017 - 02:53:03 PM »
Took a drive to Smileys Racing to buy 5 gallons of VP 110 leaded. Adjusted the idle, checked timing , it's at 12 btdc , then tried to reduce exhaust manifold leak and decided to snap one of the studs.
Still has the original turquoise paint on the bolt.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline xtopfuel
Re: Broken exhaust manifold stud
« Reply #1 on: May 06, 2017 - 04:02:15 PM »
Ugh that sucks
Offline 73440
« Reply #2 on: May 06, 2017 - 05:20:18 PM »
It turned very easy, so it was probably going to let go soon.
Now it matches the starter bolt threads in the bell housing that are stripped.
40 year old engine will do that.
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline xtopfuel
« Reply #3 on: May 06, 2017 - 11:25:53 PM »
True
Offline mopar jack
« Reply #4 on: May 07, 2017 - 09:43:37 AM »
I have had that happen on the drivers side rear bolt, just broke off with no torque.
Offline 73440
« Reply #5 on: May 07, 2017 - 03:54:11 PM »
 I recently replaced the header with the exhaust manifold and maybe it's possible that with the heating and the cooling and the different expansion rates of cast iron and steel tubing the stud stretched it a little bit because it was fine a month or so ago when I last checked .
This stud was drivers side second from front.
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline 67vertman
  • Member since 9-23-2005
« Reply #6 on: May 08, 2017 - 01:35:11 PM »
Sorry hear that.   :hyper: Hopefully it is not flush to the head and you can get it out easily .  :2thumbs:
Offline 73440
« Reply #7 on: May 08, 2017 - 02:19:39 PM »
Probably flush, it snapped right at the start of the threads.
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline 340-FOUR- BARRELL
« Reply #8 on: July 20, 2017 - 12:13:18 AM »
Been there several times. Used the wick method with paraffin to remove snapped exhaust manifold bolts.
Offline 1 Wild R/T
« Reply #9 on: July 20, 2017 - 01:17:50 AM »
Weld a nut onto it & unscrew...
Offline 73440
« Reply #10 on: July 20, 2017 - 06:56:44 AM »
Thanks, I need to do some work on this , will try the parrafin first and have the welder ready to go also.
Thinking of getting new set of studs installed all around while doing this repair.
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
