Author Topic: weight of 74 cuda  (Read 1820 times)
Offline b5blueaar
  • Mad Max Cuda
weight of 74 cuda
« on: July 02, 2005 - 10:33:20 AM »
anybody know how much a 74 cuda with a 440 auto weighs?
Offline 4Cruizn
  • HEMI FISH
Re: weight of 74 cuda
« Reply #1 on: July 02, 2005 - 10:38:11 AM »
Somewhere around 3200-3400 pounds!!   :thumbs:
« Reply #2 on: July 03, 2005 - 12:33:14 AM »
my 74 was very heavy , it was 3800 with a small block
Offline Ravage
  • 1974 318 'Cuda
« Reply #3 on: July 11, 2005 - 08:45:08 PM »
I seen this nifty thing on some educational program about how to calculate the weight of a car.Measure how many square inches of each tire are making contact with the ground times the PSI of that tire.Add all four together to get the weight.
Measure the tire contact surface by wedging paper under the tires and measuring the distance the two pieces are apart.front/back X side/side = total square inches. (times PSI is the weight that tire is holding)
Does it actualy work?Never tried ,let us know  ;D
"I flipped off a box of kittens once..." (Tycho on being evil)
Offline GoodysGotaCuda
« Reply #4 on: July 13, 2005 - 09:33:19 AM »
Sorry to Hi-Jack, but anyone guess the weight of my 72 318-904-8 3/4" rear?
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline ragtopdodge
« Reply #5 on: July 13, 2005 - 12:53:00 PM »
Hemi Challenger (for comparison purposes):
http://www.engine-power.com/dodge/1970_challenger_rt_hemi.html
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
1976 Dodge Warlock
Offline b5blueaar
  • Mad Max Cuda
« Reply #7 on: July 13, 2005 - 04:03:42 PM »
hey ravage,
your theory sounds correct, but did not work out for me.
It might work with slicks on the car.
With street tires, there is a lot of the "patch" area that is not actually rubber touching the ground.
There is a lot of void in the tread recesses and that messes up the calculations.
If you had slicks on, then all the patch area would be tread and I think it would work.
But with street tires, the patch measures much larger than it actually is.
My 74 cuda with 440 calculated out to be 5259 lbs and showed that the rear is 300 lbs heavier than front which we all know is not correct.
Offline Mr. 6pak2go
  • Restore it dont crush it!
« Reply #8 on: July 13, 2005 - 07:52:03 PM »
my 72 says 3240 on the title but thats a 318 car id say about 35-3600 with the rb!!
My family, My cars, My guns three things il fight for!!
Offline Ravage
  • 1974 318 'Cuda
« Reply #9 on: July 19, 2005 - 04:46:54 PM »
I guess you cant belive everything you see on t.v. ,sorry for the misinformation ,but it was in the pursuit of knowlegde and didn't cost much to perform at least  :-\
