Author Topic: 73' Cuda Brake Problem  (Read 911 times)
Offline Trainguy
  • Newbie
« on: May 10, 2017 - 07:11:17 AM »
I have a 73 Cuda that had disk on the front an a 8 3/4 rear end drum set up on the rear brakes worked fine. Over the winter replaced that with a Dana 60 with Wilwood disk set up. Brakes have been bled an fluid level checked several times with no leaks.  The power booster was an is a Bendix 12305 an a 3461187 master cylinder. THE PROBLEM IS; with the power booster connected the brake pedal with the vehicle running goes right to the floor when pressed. In the manual mode ( no vacuum ) I have brake pedal( not good brakes but brakes ). What happened to the brakes?
Thanks
Trainguy
Offline Rich G
Re: 73' Cuda Brake Problem
« Reply #1 on: May 10, 2017 - 09:59:26 AM »
You know what they say, if it ain't broke don't fix it! If I read that right you have 4 wheel disc now? I'm assuming you bench bled the m/c and there is no air in the system. If you pump the brakes do you have a pedal then? I would check to see if the rod in the booster is correct or adjusted right if it is adjustable. I'd call Wilwood and ask them if you have the right m/c . I know on hot rods they have residual valves in the line to keep some pressure on. Converting things never seem to go smooth!
Offline xtopfuel
« Reply #2 on: May 11, 2017 - 06:03:22 AM »
get a set of brake line clamps, clamp all hoses front and rear have a helper press pedal and remove each one at a time, when pedal drops your issue is in that wheel
Offline Trainguy
  • Newbie
« Reply #3 on: May 11, 2017 - 06:46:41 AM »
Thanks guys for your reply's. I will try these idea's.
« Last Edit: May 13, 2017 - 06:40:47 AM by Trainguy »
