Author Topic: 340 vibration and hesitation with a short history  (Read 3456 times)
Offline 73_Cuda_4_Me
Re: 340 vibration and hesitation with a short history
« Reply #15 on: May 17, 2017 - 08:20:45 AM »
Depending on specs of the cam, and if you are running stock distributor with vacuum advance still connected...
My 70 340 engine (spare engine in 73 now) with 600 cfm Eddy Performer carb, Comp cam, and headers had way too much advance with vacuum advance connected... the cam liked about 18 degrees advance at idle, and mechanical added 30 that, then vacuum added another 15... had lots of spark knock under load at cruise speeds...
I disconnected vacuum advance, and built a limiter plate to restrict total mechanical advance to 18 (36 degrees all in at 3000 rpm)...
If you don't have adjustable timing light, it's the best investment I would recommend. Then get timing readings from idle up to about 3500 in 500 rpm increments... if you end up with high 40's advance or higher, you'll have to limit it (plate or electronic distributor).
If you are running stock (or upgraded) dual-plane manifold, the carb setting could be rich on side feeding 2-4-6-8... doesn't take much to darken the plugs a few shades!
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
Offline 734406pk
  • Andy
« Reply #16 on: May 17, 2017 - 09:57:05 AM »
Factory exhaust manifolds are gone...Blackjack Headers were installed back in the 80's!
I suspected the cast iron manifolds were replaced with headers, but wasn't sure. So, the heat riser valve is out of the mix. Take a compression test and see what you have, then tune up changing the high voltage side parts (distributor cap, rotor,coil/ plug wires and spark plugs). Fresh fuel in the tank? Replace the fuel filter as needed. Start with the simple things first. Good luck
« Last Edit: May 17, 2017 - 10:28:45 AM by 734406pk »
