Author Topic: FAST EZ EFI 2.0 KITS DROP IN PRICE!!  (Read 1535 times)
Offline CUDA8U
« on: May 15, 2017 - 06:48:43 PM »
 I made a couple calls today to get opinions on an efi system on my 512 stroker.I was made aware of a price drop from EZ EFI to keep competitive.Why couldn't they offer this special pricing before? I was also told the FiTech systems afre cheap junk right down to the fittings.
 Let's hear your take on comparing the 3 main units : FAST EFI vs Holley Sniper vs FITECH.
« Last Edit: May 15, 2017 - 06:52:43 PM by CUDA8U »
Offline cudabob496
Re: FAST EZ EFI 2.0 KITS DROP IN PRICE!!
« Reply #1 on: May 15, 2017 - 07:14:12 PM »
FI Tech has got good reviews.  Others are coming down due to FI Techs prices.
The FI tech fitting issue is supposed to be solved.
2011 Kawasaki Z1000
Offline DocMel
« Reply #2 on: May 22, 2017 - 02:53:47 PM »
I am surprised that no one else had interjected:
Bottom line, I hated by FAST EZ  (1.0):  Now understand, that wasn't my first FI install:  I have used the E Brock system, and the FI Tech.
The E brock system was GREAT:  But many many hoses, wires, etc.
FAST:  I could NEVER get it to run right, customer service sucked, and there are many posts on the web that stated they had probs to;  It go so bad I had it removed, and it has sat on my work bench for over a year now.  Plus many wires, hoses, etc, etc.
FI tech.  Quite frankly, the easiest and cleanest system I installed.  And it works, period.
« Reply #3 on: May 24, 2017 - 03:35:03 PM »
I built my own system & it was awesome , mutiport not T body too .
I am glad you like the FITech system
Offline john h
« Reply #4 on: May 26, 2017 - 01:35:45 PM »
I have the FITECH system.  I don't have experience with the others.  the install was straight forward.  The fittings were difficult.  That was also my first try using that type of push lock fitting.  I am running the fuel command and also using the timing control.  The price point of the unit was a major factor in choosing it but I could not be happier with the final result.  I would use this system again if I had another project.  I called tech support for 1 question and they actually answered the phone.  I did wait about 5 weeks for mine.  It's been installed for 1 full summer and I used it for about 4,000 miles. looking forward to more easy starting, good throttle response and the piece of mind knowing that I won't be stranded.  It made my car a lot more reliable compared to the 3 different Carbs that used to top the motor.
Good luck.
John
73 Cuda
360 Crate motor
FiTech Fuel injection
727 Trans (wishing it had Over Drive)
