Author Topic: Starting Issues?  (Read 3741 times)
Offline cv70chall
  • 1970 Challenger
Starting Issues?
« on: May 17, 2017 - 09:34:55 AM »
I have a 70 R/T, 440 Auto with Holley 670 Avenger. Car will fire up normally cold, and 9 times out of 10 normally when warm.
Every 4 or 5 starts, it behaves as if it's not getting fuel- and struggles to start.
Battery and Starter are fine- checked.
Carb issue?
Fuel Pump?
S.O.S.
Offline 69bcuda
Re: Starting Issues?
« Reply #1 on: May 17, 2017 - 09:50:20 AM »
When it has trouble and don't start, pull the air cleaner, pump the throttle once by hand and note the pump shot you get. No shot, low fuel in carb or carb pump is failing.
Offline cudabob496
« Reply #2 on: May 17, 2017 - 01:34:24 PM »
I had to drill small holes in throttle plates for engine to get enough
air when starting. The newest Holley carbs have a bypass valve
that accomplishes the same thing.
Make sure engine well grounded with big cable/strap.
What is initial timing?
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
« Reply #3 on: May 17, 2017 - 08:07:31 PM »
Carb issue?
Fuel Pump?
S.O.S.
Are you using an ethanol blend fuel?
Offline cv70chall
  • 1970 Challenger
« Reply #4 on: May 18, 2017 - 07:34:38 AM »
Yes, 93 Oct when I have to. I try to stay with REC90 when I can.
Offline cudabob496
« Reply #5 on: May 18, 2017 - 12:24:52 PM »
heat shield around carb? insulated fuel lines?
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
« Reply #6 on: May 18, 2017 - 08:19:23 PM »
Common problem with ethanol blend fuel, it has a lower boiling point. When you shut down the engine, the carb can "heat soak"  boiling off the fuel.  You can try a carb heat shield.
http://www.coolcarb.com/index.html
Are you exhaust cross over ports blocked?
Offline cudabob496
« Reply #7 on: May 19, 2017 - 12:08:31 AM »
easy to make your own with sheet metal.
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
« Reply #8 on: May 19, 2017 - 12:45:18 AM »
I think the Poly-Core insulating material used in the Coolcarb plate has the advantage on blocking heat.
Offline cv70chall
  • 1970 Challenger
« Reply #9 on: May 23, 2017 - 03:06:53 PM »
Order in!
Question. I need to know exactly where the idle adjustment is on the Street Avenger 670..
Please
Offline cudabob496
2011 Kawasaki Z1000
« Reply #11 on: May 24, 2017 - 03:40:40 PM »
Idle speed is the screw on the throttle shaft lever
Idle mix is 1/3 of the up the sides of the metering plate between the carb bowl & throttle body
Offline cv70chall
  • 1970 Challenger
« Reply #12 on: May 26, 2017 - 04:18:33 PM »
Not to be stupid, but I can't locate it on the diagram.  Lol
Offline cudabob496
« Reply #13 on: May 27, 2017 - 01:20:47 AM »
oops, sorry, my diagram only shows one side of carb.
2011 Kawasaki Z1000
Offline cudabob496
« Last Edit: May 27, 2017 - 01:28:51 AM by cudabob496 »
2011 Kawasaki Z1000
