Author Topic: pst torsion bars  (Read 4029 times)
Re: pst torsion bars
« Reply #15 on: May 20, 2017 - 05:17:18 PM »
With the front that low, you're probably not going to be able to run the factory bump stops on the lower control arms. You can buy short 1/2" tall bump stops online.
Offline 73_Cuda_4_Me
« Reply #16 on: May 21, 2017 - 08:20:45 AM »
 :2thumbs:
You'll want to keep an eye on ground clearance for exhaust connections... Speed bumps, some driveway slopes, and some auto shop ramps can have considerable 'impact' on clearances...
 :22yikes:
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
Offline jim.k
« Reply #17 on: May 25, 2017 - 09:12:49 AM »
So my new torsion bars arrived from pst . I will be installing them and rebuilding the front end this weekend. I know there is a left and right bar but is there a front and back ?  Doesn't look like it matters but ....
« Reply #18 on: May 25, 2017 - 10:36:32 AM »
Front to back doesn't matter. Right and left do matter because of the offset in the hex.
« Reply #19 on: May 25, 2017 - 10:39:37 AM »
Left and right only.  Front/back doesn't matter.  The bar still twists in the same direction.  If there is an L or an R on the end of the torsion bars, it might be a good idea to have those showing out the back.  Just so you can glance at them and know they are on the correct side.
Offline jim.k
« Reply #20 on: May 25, 2017 - 10:56:16 AM »
Ok that's what I thought. Just making sure. Thanks
