Author Topic: Correct Anti-Freeze???  (Read 3141 times)
Offline cudabob496
« on: May 20, 2017 - 04:28:01 PM »
I use regular green Prestone anti-freeze.  But for my Aluminum LS-1 I have to use
orange Prestone DEX-Cool to protect aluminum components. So why the heck have
I not been using Dex-Cool in my Cuda, with all its aluminum components???
2011 Kawasaki Z1000
Offline 73_Cuda_4_Me
Re: Correct Anti-Freeze???
« Reply #1 on: May 20, 2017 - 07:37:14 PM »
 :clueless:
 :dunno:
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
Offline 734406pk
  • Andy
« Reply #2 on: May 20, 2017 - 08:45:12 PM »
Wow! That's opening a big box of scorpions! I use green Prestone formulated for aluminum (high silicate) classic cars. I stay away from The HOAT organic acid base antifreeze at all costs. That's just me though!  :bigsmile:
Offline cudabob496
« Reply #3 on: May 20, 2017 - 09:35:40 PM »
OH GREAT, I PUT SOME ORANGE IN MY CAR!!!!!
Q: Can I mix green coolant with orange coolant?
This is one of those questions usually asked after the fact, and usually engine damage has already occurred. The green and orange coolants do not mix. When mixed together they form a gel-like substance that stops coolant flow and consequently the engine overheats.
There are some coolants that claim compatibility with Dexcool, but I would rather err conservatively and add what the system is supposed to take rather than gamble. To guard against major engine failure, read on.
What exactly happens when these coolants are mixed?
The coolants chemically react and form a gel rather than a liquid. The coolant stops flowing through the system, clogs up coolant passageways and water jackets, radiators, and heater cores. The water pump overheats and fails due to a lack of lubricant in the coolant. Head gaskets blow, heads warp, and the engine suffers major damage.
2011 Kawasaki Z1000
Offline cudabob496
« Reply #4 on: May 20, 2017 - 09:48:45 PM »
hard to believe, if true, that GM would make an orange antifreeze, that if accidently mixed with green
antifreeze, it forms a gel and destroys your engine!!!!
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
« Reply #5 on: May 20, 2017 - 09:50:54 PM »
Here come the scorpions! LOL!
Drain and flush the cooling system if you have any second thoughts. :2thumbs:
« Last Edit: May 20, 2017 - 10:04:58 PM by 734406pk »
Offline cudabob496
« Reply #6 on: May 20, 2017 - 10:55:28 PM »
yep, doing it now.
The orange has to be used in GM cars back from the 1990s, or it voids
the warranty.
2011 Kawasaki Z1000
Offline Cudakiller70
« Reply #7 on: May 20, 2017 - 11:33:09 PM »
 :poopoke: Wow that's some warranty  :bigsmile:
« Last Edit: May 20, 2017 - 11:39:32 PM by Cudakiller70 »
The above is just my opinion
John Adams
Offline cudabob496
« Reply #8 on: May 21, 2017 - 12:24:49 AM »
so, if I flush system, should I use orange, since its made for aluminum?
2011 Kawasaki Z1000
Offline cudabob496
« Reply #9 on: May 21, 2017 - 12:30:21 AM »
OK, Car and Driver says if car born with green, stick with green. I'm still gonna add Royal Purple
additive for coolant.
http://www.caranddriver.com/columns/top-it-up-with-green-or-orange-which-antifreeze
2011 Kawasaki Z1000
Offline Beekeeper
« Reply #10 on: May 21, 2017 - 12:52:48 AM »
Good article. Glad I read this thread. I've used different kinds over the years without thinking too much about it. Makes me want to flush all my cars. I always worry about stuff corroding away since they aren't daily drivers.
Offline cudabob496
« Reply #11 on: May 21, 2017 - 01:55:55 AM »
adding zincs gives extra protection.
Also, article noted that corrosion protection chemicals in anti-freeze degrade over time.
2011 Kawasaki Z1000
Offline 60K T/A
« Reply #12 on: May 21, 2017 - 02:51:55 AM »
I use red anti freeze in all my engines and stick a anode in my rad. I also flushed the orange from my LS1 and replaced it with red.
« Last Edit: May 21, 2017 - 02:55:30 AM by 60K T/A »
T/A, Survivor,
M37B1 Sold
W350
It took about 35 years for the "politicians" to RUIN this country just to line their pockets
Offline xtopfuel
« Reply #13 on: May 21, 2017 - 06:07:55 AM »
I do believe the red and green are exact chemicals but Toyota colored the coolant to red, many confuse red with orange
Offline cudabob496
« Reply #14 on: May 22, 2017 - 02:52:25 PM »
Ya, I just refilled the coolant system with about a 80%/20% water/Prestone
ratio, because the more water, the better cooling.  And, put in two bottles
of Purple Ice.  Also, on Prestone bottle, it says mix with any color, so all these
diff colors seem to be a big smoke screen.
https://www.summitracing.com/parts/rpo-01600
2011 Kawasaki Z1000
