Author Topic: 73 cuda - 73 challenger steering columns  (Read 1006 times)
Offline jim.k
« on: May 25, 2017 - 03:43:57 PM »
will a steering column and console with shifter be the same in a 73  challenger and 73 cuda ?  my cuda has column shift.  got a chance to get steering column and console with shifter out of a 73 challenger for free.
Re: 73 cuda - 73 challenger steering columns
« Reply #1 on: May 25, 2017 - 03:50:21 PM »
Cuda and Challenger columns should be the same.
Offline Moparparts
« Reply #2 on: May 25, 2017 - 04:09:03 PM »
73 Steering column , shifter, linkage and console will all be the same. The difference will be on the column shaft and coupler if it is for manual or power steering
Offline jim.k
« Reply #3 on: May 25, 2017 - 04:30:12 PM »
My car has manual steering. If the chally has power can the parts be swapped from my column to make it  work in my car ? I would assume so ?
« Reply #4 on: May 25, 2017 - 10:22:32 PM »
Yes, you can install your original steering shaft into the floor shift column.
