Author Topic: 383-440 TTI Shorties and Alternator w/VR and wiring  (Read 2917 times)
Offline Tazinhawaii
« on: May 29, 2017 - 11:05:36 AM »
Hello everyone,
  Well, Some know I wiped my camshaft which sent metal everywhere.  So I decided it's time to upgrade to a 522 from my current 440.  So this gives me a chance to swap some other parts.  So, my 65amp alternator probably isn't enough for my 1400w stereo and the new electric fan setup so I'm selling it with the external voltage regulator and the wiring for it (including lead to the idle control solenoid.  All is basically new as the car has a little over 700 miles on it since original rebuild. Selling the complete setup for $100 shipped to the lower 48.  Pics below.
  Also putting up for sale my TTi shorty headers and mid pipes.  Again, I'm upgrading with the extra cubes to long tubes IF I can sell these.  If they don't sell before the new short block arrives, then I'll just use them.  Cost me over $800 last fall.  Selling for $440 shipped to the lower 48.  Also includes hardware and new collector gaskets (doesn't include exhaust flange gaskets though).  These are the unpolished ceramic coated with thermal barrier version.  The midpipes are required for installation and will be provided.  They are currently welded to my exhaust system but will cut them out and provide.  Also included is a welded in O2 bung (will provide plug if you don't want to use an O2 sensor).  Again pictures below.  The oil on the headers is fresh and should clean right off.  This is from running the car with the valve covers off temporarily trying to determine what was going on with the valve train.  You'll have to excuse my welding on from the midpipe to my exhaust.  I did it with it installed in the car and it kind of became the more weld wire the better quest...  But they don't leak!  :)  Here is a link to the tti webpage for them.  http://www.ttiexhaust.com/MoparClassics-Headers/44025-Shorty/TTi44025.htm.  Please note that a mini starter is required and read the additional notes from tti on the webpage.
  To prevent any question, the first person to reply to this post saying they want either of these gets dibs for 5 days.  I accept paypal.  You can message me as well, but the line forms from replies to this topic.  Thanks.
Derrick
1971 Cuda 440 six pack.  Original TX9 Black on Black.  Located in southern NH.
Offline ctaarman
  • Newbie
Re: 383-440 TTI Shorties and Alternator w/VR and wiring
« Reply #1 on: May 31, 2017 - 10:37:12 AM »
Hi Tazinhawaii,
By chance are you interested in sellling your fast idle solenoid from your 440?  If so is it a six pak?
Also, what is the date code on front and back of your alternator?
Thx,
John
Offline rutro
« Reply #2 on: May 31, 2017 - 07:17:28 PM »
Hi Tazinhawaii, if the solenoid is not off a six pak, I would be interested. That is if you are not going to need it. Maybe even the carburetor. Depending what it is. Thanks, Mark
Offline Tazinhawaii
« Reply #3 on: June 01, 2017 - 02:17:41 PM »
Hi,
  The date code of the alternator is from 1985.  It's not an original, it's something the previous owner got from an autoparts place I assume.  The idle solenoid is for a six pack setup and I haven't decided to sell it yet...  I'm going to see if I can devise a way for it to work with the new 1 wire alternator.  If not I may sell it in the near future.
Thanks,
Derrick
Offline Fern
« Reply #4 on: June 01, 2017 - 05:30:58 PM »
The TTI link dosent work. Do you know if the shorties will work with power steering and fast ratio arms?
Offline Tazinhawaii
« Reply #5 on: June 01, 2017 - 05:55:45 PM »
Interesting. I don't know why the link doesn't work, but it doesn't for me either.  You can go to ttiexhaust.com directly and find them that way.  They do work with power steering (I have PS).  They should work with the fast ratio arms as they would be shorter that the stock arms which would move the tie rods and cross bar even further out of the way.  But I don't know for sure as the website doesn't mention fast ratio arms and I don't have them..  I've cut and pasted the info from the website below, but it's not all pretty like the website.
Header #44025
1-3/4" SHORTY HEADERS
Click image to enlarge
FEATURES ...
Designed for:  383-400 B-engines & 440 RB-engines
Primary tube size:  1-3/4" O.D.
Collector size:  2-1/2" with 2-1/2" 3-bolt flange
Flanges:  3/8" thick, laser-cut, contoured for a leak free fit
Material:  Constructed of 16 gauge mild steel tubing.  Mandrel bent on sophisticated computer controlled bending machines for precise fit and uninterrupted exhaust flow. The mandrel bending process maintains a constant inside diameter of the tube for a smoother finish with no restriction of flow and no crimping of the tubes.
One piece design:  One piece header tubes / No slip tubes
Under chassis design:  Above the steering center link design offers maximum header to ground clearance
Shorty header design:  2-1/2" Header Adapter Pipes required to transition Exhaust systems to headers
Recommended for:  Up to 475 horsepower
Header set includes:  Header gaskets & header bolts
APPLICATIONS
PART NO'S & PRICING
COMPONENT PARTS
OPTIONAL: O2, EVAC, EGT
~  Our headers were designed to fit with the engines located to the factory specifications.  If the engine is not located correctly in the chassis, the headers will not fit properly.  We strongly suggest you check your engine location prior to installation.
~  Due to various manufacturing designs, aftermarket parts, engine configurations, suspension combinations, etc... TTi cannot ensure headers and exhaust systems to fit all combinations.  However, we have done our best to accommodate both factory and aftermarket component combinations.  In some cases, slight modification or repositioning may be required on your part to clear the specific situation.
APPLICATION   Verify headers will fit your application combinations...
Platforms:
67-76 A-BODY, 66-74 B-BODY and 70-74 E-BODY CHASSIS.
[Check your engine location:  See FN39 for the factory dimensions]
37,  39
Engine Size:
383-400 B-ENGINES & 440 RB-ENGINES
OEM
BULLDOG
EDELBROCK E-STREET
EDELBROCK PERFORMER RPM
INDY-EZ
STAGE 5
440-SOURCE
FACTORY 915
FACTORY 452
>  Cylinder Head Studs:  Head studs may be used on the Passenger-side, however, the header tubes will not clear the cylinder head studs below the #3, #5 and #7 cylinders on the Drivers-side.  We recommend ARP bolts for clearance in these areas.
Spark Plugs:
STRAIGHT or ANGLED
Headers are designed with adequate plug clearance for angled plugs.
Front Suspensions:
Stock with torsion bars or
Coilover without torsion bars (RMS Alterktion, Magnumforce XRT Tubular K-frame or Control Freak)
33
Auto Trans:
YES
53
Standard Trans:
YES   ... A-body applications with a Standard transmission requires a modified Z-bar.  Modified Z-bar sold separately #ZB307.
53,  55
Floor Shift:
YES
Column Shift:
Push Button:
YES
Manual Steering:
YES
Power Steering:
YES
Starters:
383-400 with a 10.5" flywheel:  Must use a RobbMc Perf Starter #3005
440-727 Trans:  Must use a RobbMc Perf starter #3005 or PowerMaster XS Torque starters:  9523
440-Standard Trans:  Must use a RobbMc Perf starter #3005
Flywheel:
10.5" 130-tooth ring gear:  YES, headers will clear.
11" flywheel, 143-tooth ring gear / 383-400 B-engines:  NO, headers will not clear.
11" flywheel, 143-tooth ring gear / 440-RB engines:  YES, headers will clear, however, you must use a RobbMc Performance starter #3005.
Bell housing:
ALL
Oil Filters:
OEM
Oil Pans:
ALL
Clutch Linkage:
OEM   ... A-body applications with a Standard transmission requires a modified Z-bar.  Modified Z-bar sold separately #ZB307.
55
Steering Linkage:
OEM with torsion bars or Rack & Pinion without torsion bars
Headers will not clear the uniSteer Performance Rack & Pinions.
Firm Feel fast ratio pitman & idler arm:  ? (Fit-check required)
12,  33
Valve Covers:
OEM, Cast aluminum, Stamped steel, Fabricated aluminum
PART NO'S & PRICING ...
Header Finish
Part No.
Price
Footnotes
Raw (Bare Mild Steel)
# TTi 44025-C0
$ 550.00 set
C0
Nickel Chrome Plated
# TTi 44025-C1
$ 571.00 set
17,  C1
Ceramic Coated with a Thermal Barrier
# TTi 44025-C4
$ 673.00 set
17,  C4
Polished Ceramic Coated with a Thermal Barrier
# TTi 44025-C5
$ 705.00 set
17,  C5
Offline Fern
« Reply #6 on: June 02, 2017 - 06:27:37 AM »
Pm sent
Offline Tazinhawaii
« Reply #7 on: June 03, 2017 - 04:01:03 PM »
To answer some questions on fitment, here are a couple pictures I took when I pulled the motor/trans/k-member from the car last time.  It kind of shows where the fitment of the headers are, although the pics weren't specifically taken to show the fitment.  Hope this helps.
Derrick
« Last Edit: June 03, 2017 - 04:03:09 PM by Tazinhawaii »
Offline javakm70cuda
« Reply #8 on: August 09, 2017 - 07:34:34 AM »
Are you selling the correct mini starter for the tri setup?
Offline Tazinhawaii
« Reply #9 on: August 11, 2017 - 07:16:59 PM »
Sorry, no.  The starter is still being used.
