Author Topic: Looking for 1970 Challenger T/A heads  (Read 1171 times)
Offline daxus99
« on: May 30, 2017 - 07:23:09 PM »
New member here, in the process of restoring a 1970 Challenger 340 T/A. My 340 T/A block is currently at the machine shop getting rebuilt but unfortunately the original heads are badly pitted/corroded. If anyone has a set of 340 T/A heads in good condition please get in contact with me. Thanks.
Offline AARTA340
Re: Looking for 1970 Challenger T/A heads
« Reply #1 on: May 30, 2017 - 07:51:49 PM »
The special heads are out there, but not cheap. Hopefully your rockers are useable. Heads are easier to find than the rockers. Good luck with the hunt.  :cheers:
Offline daxus99
« Reply #2 on: May 30, 2017 - 08:18:28 PM »
Thankfully all of my rocker arms and rocker shafts are in good condition. All I need is a good set of heads to keep the ball rolling on my restoration.
Offline AARTA340
« Reply #3 on: May 30, 2017 - 08:41:28 PM »
Be sure you get the correct ones, take pictures of yours for comparison. The ones below on  :ebay: are not true AAR/TA heads. If you compare your heads and they are correct, you will see the difference in the push rod milling holes. hope this helps.
http://www.ebay.com/itm/1970-Challenger-Barracuda-Rare-Date-Coded-AAR-TA-6-Pack-3418915-J-Heads-/161831854467?hash=item25adee2183:g:gOcAAOSwv0tVDH0M&vxp=mtr
Offline daxus99
« Reply #4 on: May 30, 2017 - 08:54:04 PM »
Thank you for your input. I have seen this posting on ebay already and I'm surprised that no one has corrected the seller yet. I am aware of the offset location of the rod holes. I just hope someone on this site has a good set they are willing to part with.
