alright, I readjusted all my glass so that it appears to be similar to the picture posted, one question in doing so though...since the door swings closed the glass falls on the outside kind of compressing the seal to the side, should it fall above ,below or at the seal seam flap?
Then because the 1/4 rolls up to the seal, should the rear and top edge of glass fall into the flap /slot in the seal? or just push up to it?
also the rear rail that the rear edge of the 1/4 glass slides up and down in, that channel has a screw in the top and a clip at the bottom, the bottom lines up with a bracket welded to the fender well, does this just clip over it and is allowed to slide in and out or should it be fastened somehow?
